My two year old TV seems to be having some trouble with the upper right hand corner. It seems to bow down. No matter what I adjust it in the service menu, I can't seem to straighten it out. I've tried the trap settings and all the Horizontal and Vertical settings with no success.
I don't like messing around with the service menu settings, so I made sure I wrote all the existing settings down before I started. Unfortunately, I just can't take having the top portion of my letter boxed movies slanting down and to the right anymore.
Any suggestions on correcting this issue, like the order of adjusting the settings, etc., would be greatly appreciated.
I have a 20 inch Toshiba LCD tv, model 20vl14. I want to mount it on the wall. I can't seem to find the right size screw for the four mounting holes on the back. Any idea what size they are?
donnamae
I just purchased a Toshiba TV/VCR combo, MV20P2, so i'm still adjusting, BUT - can you record an program and watch a different program at the same time??
put the volume on 0, then hold the volume down button, while holding the number 9 on the remote. it should pop up. just try not to dick around with the settings tho.
