Silver Member Username: CenusHicksville, Ohio Usa Post Number: 245 Registered: Jan-05 | what would happen if you took a crappy sub like a l7 or somthing similer and changed the motor to something a lot better like the xbl or something similier would it make the sub better or is it even possible to do. |
Bronze Member Username: Iowahawks19Post Number: 35 Registered: Jun-05 | the L7 just has crappy SQ, do you mean take a horrible SQ subs and try to make it sound better?? or what are you trying to get at here, and if you did change the motor it would most likely require a professional |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 246 Registered: Jan-05 | im not going to do it i was just wondering if it could be done and would it improve the subs sq. |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 281 Registered: May-05 | its done quite frequently. not necessarily w/the L7. but my brahma has a sadhara motor. this is a picture of an orion and se, i believe. http://www.realmofexcursion.com/videos/Resonant%20Engineering/sx15.8.wmv makes things interesting and different. but as in the case w/the L7, not all transplants make for an improved driver. |
