Anonymous | how many ohms do i wire my dual 4 ohm sub to? (12w6v2)??????????????????????? |
Bronze Member Username: Dominirica012Charlotte, North Carolina US Post Number: 74 Registered: May-05 | 2 |
Anonymous | so the e1400d a good amp for it? |
Silver Member Username: AraknidBOCA , FL U.S. Post Number: 754 Registered: Nov-04 | Is your amp 2 ohms stable? Quick shot you cant just tell them to wire it to a low load without asking them what the amp is stable to. |
Anonymous | so what ohm? |
Silver Member Username: AraknidBOCA , FL U.S. Post Number: 755 Registered: Nov-04 | http://www.jlaudio.com/amps/e1400.html yeah that amp is 2 ohm stable, 400 W RMS x 1 @ 2 ohm (12.5V) Its rated at 12.5 so it will actually put out more since a car runs between 13.8-14.4 volts. The sub has a RMS of 400 so it will be slightly overpowered but should be perfect at 2 ohms. |
Bronze Member Username: Dominirica012Charlotte, North Carolina US Post Number: 77 Registered: May-05 | lol...i was gonna ask himwhat amp he had but i was too lazy to type it in |
Silver Member Username: AraknidBOCA , FL U.S. Post Number: 757 Registered: Nov-04 | lol, that woulda sucked if someone asked that question that didnt have a 2 ohm stable amp and ran outside immediately after you posted and blew there amp. |
