Need a loud a$$system wit louds bass in the car an out way down the street
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 242
need a loud system wit loud bass in the car an out way down the street need 1 amp an 2 12s spendin around a grand on amps an subs if any post sum up here
Pgh, Pa Usa
Post Number: 243
an whats the best kind of box 2 get that loud bass an travel far sealed or ported
Pgh, Pa Usa
Post Number: 244
i want 2 jl 12 w3s v2s an now i just need a amp 2 power them right an wat box is better 4 them ported or sealed
Username: X_cold_x
Amsterico, NY USA
Post Number: 42
PORTED box for SPL and SEALEd box for SQ. i wouldnt roll with JL tho. If i was you Scott i would look into DD audio , RE audio , or Ascendant Audio. They make JL look like Sh!T.
Username: X_cold_x
Amsterico, NY USA
Post Number: 43
i would get the ported box.
Pgh, Pa Usa
Post Number: 245
yay i just wanted 2 no what 1 sounded better cause i make my own boxes an my brother just got 2 of those there a lil messed up but d@mn they hit hard in the sealed box than my 1 volfenhag in a ported tuned 2 28hz
Username: Invain
Michigan United States
Post Number: 2924
"PORTED box for SPL and SEALEd box for SQ. i wouldnt roll with JL tho. If i was you Scott i would look into DD audio , RE audio , or Ascendant Audio. They make JL look like Sh!T."
My god, I swear you got EVERYTHING wrong. First off, usually people use ported boxes for higher spl, but remember it's not gonna be a huge difference over sealed. A ported box isn't gonna absolutely blow a sealed box away in loudness.
Secondly, ported boxes can actually have better sound quality than sealed boxes, as long as it's built correctly. A sealed box normally has a very flat response curve, with rather sharp drop offs on either end. Properly built ported boxes can have very nice gradually sloping curves, and when tuned low sound amazing.
Third, RE, JL, DD, and Ascendant are all in the same league, and it's impossible to say what is better than what. I can tell you one thing for sure, RE, DD, and Ascendant DO NOT make JL look like $hit. That was probably the most ignorant statement I've heard against JL yet.
hahaha
down with jl hahahahaha
Username: Livinloud7
Post Number: 13
They make JL look like sh1t ? Ha
Username: Riebread77
Post Number: 57
you haven't said that you want SQ...just to make the bass heard down the street, am i right? In that case, I wouldn't go with JL...they are known as an SQ woofer...there are much harder hitting subs out there for the same $...look into 2 kicker L7's, Rockford power stage 1, mtx t9500 if you just want to move air...i'm probably leaving a view top candidates out but consider those...and by the way, port the crap out of it with a big box...u'll get your dbs...trust me.
Pgh, Pa Usa
Post Number: 250
what kind of sub should i get if i wanna be heard far away an need an amp 4 it 1 15 or 2 12s amps an subs about 800$
Pgh, Pa Usa
Post Number: 251
http://www.woofersetc.com/product.asp?0=295&1=296&3=2044 1500 watt hifonics at 1ohm an 1 12 L7 with the dual 4ohm coil http://www.woofersetc.com/product.asp?0=337&1=343&3=2412
Username: Tbolt
Atlanta, GA
Post Number: 20
what about the audiobahn immortal series, is it loud
Pgh, Pa Usa
Post Number: 252
an the ported bx tuned 2 28hz or should i do it at 30hz u tell me
Post Number: 64
go with the hifonics class D amp...pretty loud and affordable. go with 2 12" l7's...tune it to 30 hz...they r 12's...not 15's...i'd recommend 32 hz. make sure u have thesubsonic filter on.
Pgh, Pa Usa
Post Number: 253
i want 1 cant afford 2 yet stil need a buy alot stuff 4 my car but iam likein the jlw3v2s just put it in a ported 2 36hz d@mn
Pgh, Pa Usa
Post Number: 256
what will sound better farther away 28hz or 30hz
