LK Unregistered guest | The pansat 2500 is a very good receiver without some of the frills,but very dependable..what was added was an autoroll bin which automatically changes the keys data when dishnet changes them.. If U have some channels still from Dishnet,then its not a changing of the public keys problems...try rebooting it (Back of receiver,power OFF,wait 1 minute,power ON) now change the channels, and maybe scan the satellites again..U need to do much reading for a couple days to learn the programming..go to |
eral Unregistered guest | LK or anybody help with keycodes on FTA why thay not working single is good and channls are in still have no picture just downlaoding data & plaese inputdata thats it? |
New member Username: KeiraNorth bay, Ontario Canada Post Number: 4 Registered: May-05 | i am going to leave my e-mail because i need serious help genevieveromain@hotmail.com. please help |
ron10 Unregistered guest | new codes anybody please!!!!! |
Merenwen N. Unregistered guest | anyone have new codes??...Im in serious need of some keys... |
Silver Member Username: Maple_leafPost Number: 252 Registered: Apr-05 | Already posted a dozen times look around |
Anonymous | maple it may be posted a dozen times in another site, no active keys are posted as of right now. The keys posted are no longer working, if you know of a different site with the info please share with me as I cannot find the dozen postings with active keys.... |
Silver Member Username: Maple_leafPost Number: 254 Registered: Apr-05 | Posted on Monday, May 09, 2005 - 04:04 pm: -------------------------------------------------------------------------------- KEY0 B4 1C 14 6C F2 31 0D 2E Active KEY1 8A 3B CF 2F 19 8D C8 CA 09-05-05 14:54:21 |
Boozilla Unregistered guest | Anyone know where to go to get the keymaster program? Heard about it and can't find it. |
rtgrtre Unregistered guest | boozilla this is the site for you.... |
LK Unregistered guest | keymaster.exe is located at the File Share FTA area at |
eral Unregistered guest | new keys are working? |
New member Username: Douglas2005Post Number: 1 Registered: May-05 | I have a question that may not be possible. I have an extra DTV RCA receiver. I would like to change the serial number so that I can use the same card in two receivers. The card is married to receiver1 and I want to clone the receiver so that the card won't know the difference. It is for convience so that I can take my card and service with me without toting around the receiver. |
annoymous Unregistered guest | I've been having a problem with my Pansat 2500A. My satallite echo 8.6 is not working properly. Does anyone know how to fix the problem. I've entered the code and it has worked for a while, but I do not get all of my p a y p e r v i e w channels like I used to. |
LK Unregistered guest | Douglas...NO way Bud! anon...rescan the satellites...and N2 for many PPV's now |
panic Unregistered guest | all my channels are not working |
Anonymous | help |
Merenwen N. Unregistered guest | Thanks Maple Leaf |
Anonymous | My tv says no signal |
LK Unregistered guest | turn it on..and align your dish |
jdogg_33 Unregistered guest | new key - codes please???????????????? |
Unregistered guest | Hi guys! New key for Dish Network Key01: 0B 27 EC 1E A8 B9 2B 0A Enjoy |
urbabe190 Unregistered guest | NEED CODES......ASAP............TY |
Richiepooh Unregistered guest | KEY0 6a cf 0c 39 11 e7 42 60 |
sexygirl6996 Unregistered guest | new code plzzzzzzzzzzzzzzzzzzz |
New member Username: MasanielloNaples, Florida United state... Post Number: 1 Registered: May-05 | hi lg can you tell me hats up for the italian ch.639 on pansat dish net the move to to nagravision 2 ? please repond me thank you sal |
LK Unregistered guest | How to change Dishnet keys: 00 or 01 Pansat receivers................ press menu go down to parental controls, and press OK press down arrow and enter 0000 thats 4 zeros now go down to nagravision and press ok now press the right side arrow next to the ok button 11 times until it says dish network now press the down arrow 1 time key number should read 00 now now press the down arrow 1 time using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F) set the key to whatever the latest key code is 8A C4 96 93 EC 79 9D 57 ....(example only) now press the ok button! then press exit 3x to exit the menu Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats. ............................................................ Fortec key change method 1)With receiver hooked up to TV and satellite: 2)Press MENU on the remote control 3)Then right side arrow to CHANNEL EDIT 4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688) 5)Then right side arrow to turn OFF, KEYCODE FUNCTION 6)Go to NAGRAVISION and press OK 7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK)) 8)Go down to KEY Number, then right side arrow to set to "00". 9)Go down to Key Data and enter the latest KEY with your remote control. D5 6F BB 83 00 D8 B0 4E ...(example only) 10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "00" is saved. 11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01 12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only) 13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "01" is saved. 14)Press EXIT once. 15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT. 16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset Fortec buttons to use for letters Sat=a info=b tv/radio=c pause=d ?=e KEY0 6A CF 0C 39 11 E7 42 60 Active...changed today Thurs 12 May KEY1 0B 27 EC 1E A8 B9 2B 0A 12-05-05 13:05:12 |
New member Username: MasanielloNaples, Florida United state... Post Number: 2 Registered: May-05 | hello LK I was write to you yestday i put wrong letter instead lk was lg sorry can you tell me wat up for the ch 639 rai the moved in nag 2? the you thing cam up some n ew for see the channel , thank let me know sorry for my english writting SAL |
PANBA Unregistered guest | CAN WE GET TNT OR/AND ESPN FOR NBA PLAYOFFS ON DISHNETWORK? |
LK Unregistered guest | READ....U might learn your answer..we lost all the baby spoons here,so cannot spoon feed anymore.. |
sexygirl6996 Unregistered guest | hey new codes |
Silver Member Username: Maple_leafPost Number: 278 Registered: Apr-05 | KEY0 6A CF 0C 39 11 E7 42 60 KEY1 95 29 19 8E 6E 76 FB C8 Active 13-05-05 16:57:09 |
Anonymous | My Pansat 2500 gets only verticle but not horizontal channels, everything else is working fine. Any suggestions? |
Just George Unregistered guest | It would be my guess that you are using a Dish Pro LNB.The easiest way to solve that problem would be to use a dish pro channel list which you download using Gtools. The dish pro list already has the Horizontal and vertical transponders changed to vertical only, thereby allowing you to receive all of the available transponders. There is a way of doing a sat scan and changing the transponders yourself,but it requires a bit of calculations on each transponder.I would not attempt to tell you how myself,because of the complicated nature. |
Unregistered guest | hey lk PLZ HELP M I M USIN FORTECSTAR LIFETIME..WHILE DOWNLOADIN SOFTWARE IT GOT HANGED AND THEREZ NOTHING NOW JUST THE YELLO LIGHT ON RECIEVER DISPLAY.. TEL ME HOW I CAN FIX IT? |
New member Username: Cut177IslamabadPakistan Post Number: 1 Registered: May-05 | hey lk PLZ HELP M I M USIN FORTECSTAR LIFETIME..WHILE DOWNLOADIN SOFTWARE IT GOT HANGED AND THEREZ NOTHING NOW JUST THE YELLO LIGHT ON RECIEVER DISPLAY.. TEL ME HOW I CAN FIX IT? pz tel me was it da flash rom which got damaged or wat? |
Silver Member Username: Jmill1948Chester, Va Usa Post Number: 651 Registered: Apr-04 | moshin try to reflash it with the factory bin file see if that works then load the latest autoroll bin file check out al7bar.ok change the o to a t |
bummedout Unregistered guest | LK I have a fortecstar and expect it to be useless when Nagra2 is the norm. What card can I buy on ebay that will give me the nagra2 channels? |
LK Unregistered guest | None..U must SUBSCRIBE! |
da_dragon Unregistered guest | hey today i turned my tv on and the pay per viwes and the hbos dont work what i can i do or is it like that now? |
da_dragon Unregistered guest | now the code doesnt work what happened ? |
LK Unregistered guest | KEY0 12 36 3A 6F D8 F4 BE 6A Active KEY1 95 29 19 8E 6E 76 FB C8 16-05-05 15:02:56 |
da_dragon Unregistered guest | i have put those in but it doesnt work i have the pansat 2300A |
da_dragon Unregistered guest | whats going on its not working |
LK Unregistered guest | Then U're shouldn't even own an FTA!...anyone who can't flash/load an autoroll bin or manually enter Dishnet keys should SUBSRIBE to cable!..the keys work fine,its you! try a reset of reseiver (Back of receiver,power OFF,wait 1 minute,Power ON)..change the channel...rescan the satellites if necesaary.. BTW...If U're talking Bev,not Dishnet,then PPV and movies are gone forever to nagra2 (MUST SUBSRIBE TO RECEIVE)..and Bev keys have NOT changed..if U're talking Dishnet,U should give it up! |
da_dragon Unregistered guest | im giving up looks like it that sucks lol anything that i can do to get everything back |
MylkyD Unregistered guest | Thanks LK |
Anonymous | LK I HAVE THE PANSAT 2500 THE MIDDLEEASTERN CHANNEL ARE WORK BUT THE HBO,PPV,STARZ ARE NOT WORKING CAN YOU HELP PLEASE |
LK Unregistered guest | are any channels working?...U using Dishnet or Bev?...have U changed keys today?...do U have autoroll?...did U do a reset?..do U rescan the satellites again?...what birds do U get? |
sexygirl2169 Unregistered guest | new codes plzzzzzzzzzzzzzz |
sexygirl2169 Unregistered guest | Codes PLZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ ANy one plzzzzzzzzzzzzz |
jasonone@usol.com Unregistered guest | LK AM USING DISHNET I HAVE ENTER NEW KEYS TODAY I DON'T HAVE AUTOROLL (HOW CAN'T I INSTALL AUTO ROLL) I SCAN SATELLITES BUT MY BE I DID IT WRONG TELL ME HOW TO RESCAN CORRECTLY AND I HAVE 69,110,119 FOR BIRDS THANKS!!!!!!! |
Anonymous | what are birds ? ? ? |
ninmar Unregistered guest | KEY0 12 36 3A 6F D8 F4 BE 6A Active KEY1 95 29 19 8E 6E 76 FB C8 |
LK Unregistered guest | U idiots sexygils that have been asking for the new codes/keys...they're posted above here and everywhere in these forums...its people like U that ruin these forums...either READ w NEVER POST THE KEYS/CODES again here in these forums! |
dorita Unregistered guest | nooooo !!!!!! please dont stop posting rhe keys !!!!! my computer is broken so I dont have any other way to get my beloved pansat running. come on guys !!!! |
bummedout Unregistered guest | LK so the cards that people are selling like the one in this add http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5773904646&category=32845 &sspagename=rvi:1:1v_home is no good? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32843%26item%3D5773873901 &tc=photo |
Unregistered guest | Just got my Pansat and its not working I have been to a couple of sites mainly thedishguy.com and got alot of information and donwloads for the pansat 2500a but reading through the instruction, it ask for a gtools1.85 program but it say that it is courpeted and I am unable to use it. I would be very thankful for any help anyone could provide. I do have the website for the key codes but it seems that the all channels includeing ppv and adult are not working whats the deal. thank you |
LK Unregistered guest | Dorita ...U are full of BS...U need the computer to enter the keys manually!...and with autoroll U don't need the computer to change the keys ever again! Buddy..just flash the 246 autoroll bin with STB updater (many times its in the .zip file with the 246 file) then do a reset (power off,wait 1 min,power ON BACK of receiver),then U don't ever need to enter the key codes...U don't need Gtools either,only for loading channel lists which U don't need to do ,if U do satellite scan instead...adult channels and most PPV's are gone to nagra2 forever..whats nagra2?...read this |
LK Unregistered guest | bummed.. NEW VIRIGIN Dishnetwork Yellow Cards *****NAGRA2...they are NO GOOD,they have not been hacked yet...here's why... |
Anonymous | why have we lost adult channels with maestra keys? |
Mexico Mty Unregistered guest | ill try to write a bin in my 2500a, but it don't let me. This error appears : WRITE FAILED (ER1). What can i do? could you help me LK? |
urbabe190 Unregistered guest | NEED NEW CODE MI TV IS DOWN.......THANX IN ADVANCE |
Ron10 Unregistered guest | CAN ANYONE BE SO KIND AND POST THE NEW CODES PLEASE I WOULD APPRECIATE YOUR HELP THANK YOU. GOD BLESS YOU GUYS. |
New member Username: SallPost Number: 8 Registered: Apr-05 | Hi Guys!! New Keys!! 01 02 4D 58 19 8C 3A C5 C4 ENJOY! |
New member Username: SallPost Number: 9 Registered: Apr-05 | Hi Guys!! New Keys!! 01 02 4D 58 19 8C 3A C5 C4 ENJOY! |
urbabe190 Unregistered guest | I HATE THIS TV ITS DOWN AGAIN I NEED A NEW CODE......ASAP THANX |
LK Unregistered guest | Get the keys yourself.... |
eral Unregistered guest | to do the autoroll how do you download the bin into the FTA re.i have downloaded bin in my computer and typed the bin file in the browser lost after that help?? |
Maxito Unregistered guest | LK: I have a Pansat 2500a (i guess ur tired to heard that)... I don't read, I want to know what i need to downloead, from where, and then once i conected, what do i do. How do I find the autoroll.bin, and does it work in the pansat or it finds the codes online? PS: I have already GTRom Loader v3.32.exe and Pansat 2550_A_050401_235_api(N).bin ... are these useful? Got them from pansat.us PLEASE, Help me LK |
LK Unregistered guest | Read the threads about "AUTOROLL" or "How to install the autoroll"..time to start reading and posting in the correct threads...everything is too scattered here.. |
deft Unregistered guest | just me or did a grip of channels just go bye bye? |
Anonymous | u don't need keys these are the latest firmware X-75BL_050314_236cE_api------for pansat 2300A X-85BL_050405_246_api----------for pansat 2500A X-85BL2_050330_245_api--------for pansat 1500A X-87BL_050519_105_api----------for pansat 2700A X-95BL_3033_2005_0425_api--for pansat 5000HC they all autoroll. and the 2700a has a working (epg)! |
bronxbaby Unregistered guest | can someone help me, i had all the hbo's, ppv and all the good channels, (fortec)then 1 day, no signal now all the channels are canadian channels and i live in the bronx, new york. what went wrong? |
toronto baby canadain Unregistered guest | FIRST OF ALL U SHOULD THANK GOD, HE GOT U OUT OF THE BRONX, DON'T TAKE IT WRONG, I LOVE THE U.S.A. BUT LIVING IN CANADA TORONTO IS MUCH, MUCH BETTER THEN LIVING IN THE BRONX! COME ON brother, U know I'am right. Just think U can get "CITY.TV and all these wounderful canadain channels. Set back and injoy it brother and sister. |
Bronze Member Username: JderekPost Number: 25 Registered: Mar-05 | hey Bronxbaby...your sat dish moved..what sat were you on before because the Canadian sat is very close if you were on 110..Yankees rule |
Biver Unregistered guest | :-) :-) :-) |
Anonymous | must have moved a lot to the left and then moved up. not close at all. |
Aya Unregistered guest | Hi everybody ! I want to know why I can't receive chineses channels ? Are they close ? Because I receive only American channels ! Sorry if my english is not good >_<" |
Unregistered guest | I just started using the Fortec Ultra and this week noticed that some of the arabic channels from Dishnet are starting to disappear. Could somebody please explain why this happened and how I can get them back. |
LK Unregistered guest | Read the RULES here...then read the thread "nagra2 and International channels.. |
snarf818 Unregistered guest | nagra2 i think has been hack theres a new receiver on ebay for 1.926.00 dallors its call the black bird dream box no#p5 eney body email me if Iem righ |
Aya Unregistered guest | Hello Sorry but I don't know what it is nagra 2 ? I've this in Pansat 2500A ? if not , how can I have this ? Thanks in advance ! |
LK Unregistered guest | this is nagra2.... BTW...I believe these type ridiulous posts are done purposely just to bust our chops!...and there are many,so I put these in with the "ignore the jerks" catagory.. |
Aya Unregistered guest | I'm sorry if i've bother you but i'm not here to bother you , I wanted just that you help me, because I'm not english , I'm a french girl and I don't very understand too much data processing! I saw in the nagra2.org that that spoke about cards, in my machine does not have there the card, what I do have to make? And I want to know , what it is FTA , Atmega, AVR or Rom 2,3,10 or 11 ? Thanks |
LK Unregistered guest | I'm not buying that poor little innocent french girl act...Go READ like everyone else kneegrow!...I'm all done talking to you (kneegrow)..go hook another fish..that mental ward allows computers huh?...surprised! |
Aya Unregistered guest | ok, I will read, read, I thank you for having answered me! |
eImo Unregistered guest | another one bites the dust..... |
Aya Unregistered guest | By the way , what does it mean " kneegrow" ? Because I sought in the dictionary and I didn't find! |
Aya Unregistered guest | Sorry >_< , I know now LOL !! I had not seen |
BigDickDADDY Unregistered guest | for all yall having trouble with the pin code not showing up ******you must do a sat or blind scan first! then the second pin entry will show up. real simple, but can be a problem if your too damn anxious to get the free channels! |
Anonymous | i HAVE A FORTEC ULTRA AND DOWNLOAD AUTOROLL BUT ALWAYS FAIL WATH CAN i DO |
mr.hardon Unregistered guest | BigDickDADDY Just maybe U are what U say U are, but I have no doubt about U having brains. I would say little to none. So why don't U put a french-safe over your head and U will look like the DIICK U are. "COME SHOT". |
Anonymous | i heard on the radio today that BEV is all done JULY 1 how long for Dishnetwork? |
