Username: Winedrauv Post Number: 1 Registered: Jun-05
Sunday, June 05, 2005 - 18:21 GMT I have a Pioneer deh-345r from my old car, now I want to install it in another car, problem is I dont have the pioneer wiring, it's in the old car, which in turn closely resembles scrap metal nowadays =( ... Look at the picture below, I need to know which pin is for what in the plug... somebody know?
Username: Winedrauv Post Number: 2 Registered: Jun-05
Sunday, June 05, 2005 - 20:55 GMT I found this picture, it is a Pioneer 2 x 6 pin (12 pin) connector, should work out fine...
Tiellie
Tuesday, June 14, 2005 - 15:26 GMT Can you tell me wich wire is for the 12 vdc and wich colors are for the speakers?
Username: Illuminator Post Number: 557 Registered: Apr-05
Tuesday, June 14, 2005 - 16:34 GMT The same as any aftermarket headunit...
Wednesday, June 22, 2005 - 05:05 GMT I Have a pioneer 235 and i'm trying to install it in a 99' Grand Am. I have different colored wires coming from the car than the cd player? Need major help? Hint Hint I'm a first timer
Username: Geekbike Post Number: 197 Registered: Dec-04
Wednesday, June 22, 2005 - 05:28 GMT Go to Canadian Tire and buy a wiring kit. Match up the wires, solder or crimp them, and just plug it all in.
Wednesday, June 22, 2005 - 06:15 GMT We're trying to crimp them together the problem is making up the wires!! Please Help? Pioneer DEH 235 in a 99'Grand Am!! Thanks for the help
Wednesday, June 22, 2005 - 06:17 GMT We're trying to crimp them together the problem is matching up the wires!! Please Help? Pioneer DEH 235 in a 99'Grand Am!! Thanks for the help
Username: Illuminator Post Number: 659 Registered: Apr-05
Wednesday, June 22, 2005 - 06:20 GMT Knacko offered extremely useful advice. Get an aftermarket wiring harness. If you've already cut the harness, then you might want to browse through the wiring harness thread and check the links in the posts already there.
