L7 or 2 CVRs or W3v2
Username: Qcsfinest
Post Number: 7
ok i have one L7 in a ported box. It hits hard but a certain times i see what ever one is talkin about as far as Sq. What do you guys think about 2 KIcker CVRs, ported box, in a Jeep. Im sure i could get them for around the same money. or 2 w3v2.....i just need bass
My question is: Will it be as Loud or Louder, Have "OK" Sq and do they have "Bad design" rep like The L7s
Username: Mikechec9
Chicago/atlanta
Post Number: 242
can't go wrong w/JL. i loved my 3 w3v1's. i personally can't stand cvr's. if you can make them sound good, let me know.
Username: Taylor17
Kopperl, Texas
Post Number: 2197
Powered right, the 2 12w3's should get just as loud... with the sq you're looking for.
Username: Qcsfinest
Post Number: 8
well Any suggestions for louder than one L7. I dont think i want to spend over 600 or 700 tho.
Grand cherokee, ported box, need deep low bass
Username: Taylor17
Kopperl, Texas
Post Number: 2198
2 12w3's will get just as loud as 1 l7... and you can find w3's for $180 a piece
Username: Qcsfinest
Post Number: 9
I need somethin LOUDER. that 1 L7 i had wasnt loud enough
Username: Qcsfinest
Post Number: 10
I am trying to upgrade a little. The L7 kinda sounds like 2 12s but it didnt feel like 2 12s. i need some subs that are goin to shake some Sh#t up. I want people to know im comin.
Username: Thrushdtd
New York
Post Number: 133
RE xxx
Username: Mikechec9
Chicago/atlanta
Post Number: 243
http://www.soundsplinter.com/rlp_premium_series_12_and_15_inch_subwoofer.html
http://www.soundsplinter.com/rli_ignition_series_8_inch_and_10_inch_diy_subwoofe r_drivers.html
i would get either of these before any of those. louder, cleaner, less expensive. but then again i've said it 1000x.
Username: Chris_brewer
Stockbridge, GA. U.S.
Post Number: 14
What kind of amp do you have on your L7
Username: Qcsfinest
Post Number: 11
autotek 750.1.......but im gonna get the planet audio 1400D.
Username: Qcsfinest
Post Number: 12
what is a good two 12 combo in a box for around 5-600?
