Archive through June 16, 2005
Thanks for the new keys!! I've tried loading the new bin for the pansat 2500a to no avail, anyone have any suggestions? Thanks
thank u
Thank Y lk 4 the keys
Is there a fix 4 my autoroll
lifetime ultra receiver now?
If so how can i get the fix
for my autoroll
Thanks again.
gone again
gosh, one more time....need new keys again...please
anyone have new keys ..please
J. R.
If someone would post links for the keys we could
get them ourselves. TIA
s9
key changed again? anyone have the new ones?
Spanishbabe
The keys from 12:Pm are not good no more I have a hard time serch in in the net for the maestra.tv. those post in the web (maestra.tv are really old.)
need a link to fine the neew one please!!!
microdc
Working Keys
KEY 0: 8E F3 9F 87 40 C9 E2 46
KEY 1: 0C 97 B4 37 5E 3F BE 81
KEY 0:8E F3 9F 87 40 C9 E2 46 **ACTIVE
gone again
thanks microdc!
austin 316
can anyone tell me where to get keys other than maestra ? maestra used to work but not anymore.
whatdoido
so how do i make my russian channels work? Can someone help/tell me what to do step by step please?
Hamster
i've got the new keys in above. power cycled the reciever (by the back switch) nad i get a signal for about 3 minutes. after that the quality drops suddenly to ZERO with occasional spikes back up to 97. it does this if i am using the 110 LNB or the 119.
if i power cycle it again it comes back for 3 minutes and does the same thing again. is it a bad bin or something?
Username: Oddball
Windsor, Ont Canada
Thanks microdc keys work great.
NewPansatUser110
New keys work with my Pansat 2500, on 110
Thanks.
maestra.tv not working
Where are you getting the new keys from?
does anyone have a site other than this one 4 new keys
J R
http://www.maestra.tv/forums/
bevkeys.com works
Username: Timscarlet
Dayton, Oh Usa
Post Number: 38
i have got a cd i put together with info and software to make your pansat and others work with free channels. it has the newst 6-11 autoroll fix, and all the channel lists and directions you'll ever see, even with pics and video. let me know, tim
J_Yogi
Key 0 8E F3 9F 87 40 C9 E2 46 WORK FOR NOW
Dog_Girl
where do I get the autoroll for Fortec Ultra? please
thepichi
Thanks for the keys, it works. I would like to thanks every body here, this site is very useful.
J_Yogi
Does anybody know if the NEW autoroll (version 2)for Pansat 2500 is still working?
Username: Jmill1948
Chester, Va Usa
Post Number: 678
yes the new autoroll works great
kbron
KEY0: 34 12 B8 ED 07 A7 CB C8
KEY1: 25 F8 6D 52 52 2A 71 E8
This keys won't work with my Megasat yt6688, does any one has any other working keys?
kbron
Where can i find the new autoroll for the Pansat 2500A?
Does anyone have the link for the new autoroll for Pamsat 2500A?
Thanks
Joe007
Try this autoroll for Pansat 2500A
Jacklong
My mx2500 Multi star won't autoroll anymore
Where can I get the new one.
Username: J_yogi
Wpg, Mb Can
Hello, do you know where I can find the NEW autoroll for Pansat 2500?
austin 316
maestra doesn,t work J R!
Here's as good one...maybe someone has seen this problem and can help. C**Pro4*** unit. Only the Vertical's come in...NO Horizontals...Any clues..latest files used.
Username: Shithead
Here a good site http://www.dsscentral.n__/cgi-bin/files/main.cgi The 2 underscores r replaced with et for the new roll over for the pansat 2500a
austin 316
where can you find keys?
Anyone have a solution?? Why ONLY Vertical Trasponders work and HORIZONTAL do NOT on the C**L 4000Pro...all the latest files installed. Thanks!
change them all to v in manual scan
Thanks!! Will try it! Is this a common problem???
Guys, what are the latest keys(00 and 01) for dishnet?
The ones microdc mentioned at 2:53 PM don't work on my fortec receiver, any idea?
Thanks in advance
Username: Jcstubbs
Freeport, Grand Bahama Bahamas
Hey guys Newbie here I need help programing a virgin pansat 2500a where the factory setting have been deleted.
no idea what to do
Can someone help? i got an echostar receiver and jeepers program. Dish company shut down some of the channels, so they r just black, but others work fine. Can someone help me make those channels work too? Please
OmDude
Just gonna get back to all you guys and share some info that helped my tremendously. After much headache I finnaly was able to solve my problem with ALOT of help from LK's various forums that I went through my problem was not at all in the method but that the code that is listed on the Maestra webpage is neither correct or current. The newest and latest DishNetwork keycode as of 12:46am CST on 06/15/05 are as follows:
Key0: 8E F3 9F 87 40 C9 E2 46 **Active
Key1: 0C 97 B4 37 5E 3F BE 81
Using the above code and the aforementioned re-programming instructions offered by LK anyone who has the PanSat 2500 should be able to activate their directv channels...Cheers
MiKems
How to fix the Microyal ( MRX-1200 ) FTA Receiver Step by steb? My Receiver not funtion. Thanks in advance.
Chino
hey Lk, i gotta admit you are right, some of these question they're asking seems like it coming out of there as_hole and even then it makes more sense. the most stupidest are answered by there own questions.newbies are one thing but bright retards are something else!!
Later "G"
Chino,
Dog_Girl
Sorry if I'm repeating myself, but where can I find the autoroll fix for Fortec Ultra?
NAM
LK you work to hard for these people. i dont understand why no one can read but your have helped everyone and your are the man thanks
accmty
I need some infomation about Lava 2600,my sistem down very fast.
Thanks
pineappIe
lava 2600 can be flashed with a pansat bin. then download the NEW pansat autoroll.
Can anyone help??? On my C***4000Pro...Some channels are showing up as H and can NOT be seen. These need to be changed to V (I believe) How can I do this easily? Anyone know?? It has the lastest 3 files loaded. Thanks!
press menu..toggle down to manual scan..toggle down to polarization.. change to V..every tp thats H..exit
Digi
Will give it a try...many thanks!
Username: Verlanga
anyone has the new code for pansat 2500a?
6/15/2005?
thanks.
Username: Verlanga
anyone with the new code 00 or 01 for pansat 2500a?
6/15/05 pacific time 10:50am
Username: Maple_leaf
Post Number: 390
yea here. if it was a snake it would have bit you.
john wyland
Al7bar FTA Ultra_050613_276_api(NTSC).bin
is this the latest fortec auto roll ( does it work)
Post Number: 398
If it's on there it does. Nothing get's posted there unless it does.
john wyland
how do i get the adult channels on my fortec lifetime ultra to work( all other channels work great including spanish adult)
john wyland
Username: Verlanga
THANKS , I HAVE ONE LETTER THE I MISS.
THAKS AGAIN
del sol
how do i get the dult channels to work on my forec ultra...does any one know
Post Number: 399
john wyland
Posted on Wednesday, June 15, 2005 - 03:03 pm:
Call dishnet or wait fortec to get n2 hack.
del sol
my system is working great too ( for now )when should i install this new auto roll...when the sytem goes down...or now..any advise?
Post Number: 401
I would put it on now. Then you will be ready for the key change.
Username: Mty
Mexico
I have pansat 2500 A and it freeze a lot can someone tell what to do.
Mrnonoisgood
they DID IT AGAIN! darnit lol hope you guys have a new codde
heart
need new keys.
Went out at 7:03 p.m.
here are the new keys!
KEY0 8E F3 9F 87 40 C9 E2 46
KEY1 54 D5 3D AF 4F F5 2E 3A Active
15-06-05 19:21:48
shirley
Dish Network code: KEY0 8E F3 9F 87 40 C9 E2 46
15-06-05 19:21:48
Iarry
thanks......THEY WORKING :-)
Username: Barabashka
Post Number: 12
Thanks for the key
thanks, bob
Username: J_yogi
Wpg, Mb Can
I love you people, thank you so MUCH for the new keys!
AG
PLEASE SEND THE NEW KEYS
Frak
How often are these keys changed?
Username: J_yogi
Wpg, Mb Can
Key 1 54 D5 3D AF 4F F5 2E 3A are active for now
Post Number: 405
AG
Posted on Wednesday, June 15, 2005 - 08:38 pm:
Learn to read dummy
What is Key0 and Key1?
I see I have the option of entering just one key so which one am I entering? I tried both and it still says downloading nn% and it gets stuck.
NOT WORKING IN CALIF
Post Number: 407
the one that says active.
Tom Bradley
This key is working now. Thanks Shirley & Gurl21
DEL SOL
INSTALL THIS BIN..NO NEED TO IMPUT KEYS FOR NOW
Username: J_yogi
Wpg, Mb Can
Look you people, Menu, parental control, Nagravision, right arrow till you get to ****network go down one enter 1 for key, then down again and enter the #'s, press OK wait for it to flash and exit exit exit exit, good to go.
please help my pansat 2500a keeps downloading or sometimes stops when i reset the power button it starts over agian please help
Username: Kc4njx
Bradenton, Fl Usa
thanks jmh, learning this chit every day and thanks to paople like u with patience with us
Username: Kc4njx
Bradenton, Fl Usa
excuse my spelling
are those keys good for fortec receiver?
please advise guys
please advise guys
Username: J_yogi
Wpg, Mb Can
Post Number: 7
to put the new keys in, turn off the unit, and once it get back on before the autoroll or anything else, HIT your menu giude and then take it from there.
fortec star I mean.
sparrow1
what happened to LK? we need his help here.
Username: J_yogi
Wpg, Mb Can
Post Number: 8
get a pans*t, it works well for now
PL
for some reason my dishnet is not working...i entered the newest keys still dun work....any help here????
guys help please,
what are the current keys for Dishnet on the fortecStar lifetime ultra receiver? Please heeeeeeelp! I'm puting the ones mentioned on this site, but they don't work. Advise plaese.
Username: Jmill1948
Chester, Va Usa
Post Number: 683
15-06-05 19:21:48
az
well those keys dont work anymore. does anyone have any others ?
Dayton, Oh Usa
Post Number: 44
I have a cd that has the autroll automatic key finder, never input the keys again, along with all the updater software and channel lists you will ever need for pansat, fortec, coolsatt, cyclone, dreambox. let me know by email if you are interested in this info i got from hours on the internet, it even has how to videos and pics for installing your pansat. tim
Duc
Hi Tim,
My Email duc_duong2004@yahoo.com I 'm interested in this info from You... Please sent it to me Thanks........
Pepe Smith aka JDCBand
01 0C 97 B4 37 5E 3F BE 81
