Username: Prankstar008 San Diego,
CA
Post Number: 34 Registered: Jun-05
Thursday, June 23, 2005 - 05:24 GMT Can MDF be too thick. I can only get a hold of 1 and 1/8 inch thick.
Infinity_Addict
Thursday, June 23, 2005 - 06:20 GMT i don't think so, but that's gunna be one heavy @$$ enclosure!
Username: Matt12490 Post Number: 51 Registered: May-05
Thursday, June 23, 2005 - 09:05 GMT i thought you were supposed to use 3/4 so why would you think 1/8 would be heavy
Username: Addicted2bass Miami,
Florida
Post Number: 877 Registered: Nov-04
Thursday, June 23, 2005 - 13:10 GMT he said 1 and 1/8 inch thickness..not just 1/8
Username: Mikechec9 Chicago/atlanta
Post Number: 247 Registered: May-05
Thursday, June 23, 2005 - 16:44 GMT the thicker the better (build it out of concrete if you can). the idea is to make as stiff a box as possible, so that it doesn't vibrate when the subs hit. its just more expensive, and a bit more difficult/heavy to work with.
