New member Username: JechapkPost Number: 1 Registered: Jun-05 | thinking about getting a couple RE 12" subs...probably either the SE or SX, but possibly the XXX... just wondering what a good amp purchase would be for each set. thanks for your responses *note* i really dont want to spend over $500 but i will if i have to... also specs for each (from the RE site) SE-600 RMS @ 4 ohm SX-1000 RMS @ 2 ohm XXX-1600 RMS @ 2 ohm |
New member Username: JechapkPost Number: 2 Registered: Jun-05 | also to add to this, i may only purchase one if stuff gets too expensive....was planning on building my own box, if someone wants to send me additional info on that, unless someone can show me a quality manufactured box... i do have a sub box but it housed a couple of kenwood subs that were only 175 rms power... will this work? it is a plain box with holes cut out for the subs..trapezoid shaped kinda. anyway any infomation would be appreciated |
New member Username: JechapkPost Number: 3 Registered: Jun-05 | hello? anyone wanna answer this one!! thanks |
Silver Member Username: ThrushdtdNew York Post Number: 146 Registered: May-05 | some nice amps for a good price are kicker 1200.1 1200rms@2ohms or 600rms @4 for the se. MTX makes a 1000rms@2ohm for the sx. |
