How important are these??
Username: Tpizzle
Post Number: 269
two questions.
first does it make a noticable sound difference using gold screw terminals instead of push terminals on the back of a box?
second, i currently have walmart audio cables and i heard there are nice gold plated cables you can buy. would it be worth swapping out my cables, would i notice a sound difference?
thanks
Username: Insearchofbass
Post Number: 2873
If they are really cheap cables like radioshacks 20 footer was for my brother then yes swap them out. We swapped the 20 foot radio shack rca out for a 15 foot metra rca and we actually hear a volume increase across the vocal range you couldnt mistake it thats how much better it was and metra isnt top of the line. This was a good number of years ago. As far as gold plated terminals id say it would be a marginal gain but a gain none the less going to a gold connection for the price what would it hurt.
Username: Tpizzle
Post Number: 273
thanks, well my audio cables arent even radio shack i got them in a package at walmart for like $5. ill have to look into better cables.
