Best reciever for under 200 dollars???
Username: Fanfan1313
Gaithersburg, Maryland USA
In the 1980's I had my neighbor build two speakers, and two subs, hooked them in to a 1979 Pioneer and they sounded awesome. Over the years the componets have been used for various things. The reciever is operating my outdoor speakers. The subs are being used in my home entertainment system, but the speakers are being unused in the basement. Since I don't yet have a good sterio in my bedroom, I was wondering if anyone could recommend a good reciever for under or around 200 dollars (USD). This reciever would be for music only, and the room is pretty small. I also need some suggestions for a cheap sub.
Username: Virus5877
West Lafayette, Indiana USA
Post Number: 159
This would probably be the best receiver at that price range:
http://www.harmanaudio.com/search_browse/product_detail.asp?urlMaterialNumber=HK %203380-Z&status=
HK's are very musical, have TONS of power, and tend to last quite a long time.
As far as cheap subs go, check out www.hsuresearch.com they make cheap, quality stuff. any of the stf subs should work out nicely for you.
