Alpine CDA-9847 Removal
Andrew00
Ok, I just got my an Alpine CDA-9847. I wanted to hook a Alpine KCA-121B so that i can hook my mp3 player up to it. First thing i would have to do is remove the headunit. I cant find anywhere on the internet that will show directions on how to remove my alpine. I can take off the face, then a plastic trim, and i see two little clips on hte right side, but I dont want to break them. And then I dont know exactly how to run a Alpine KCA-121B from the back, out to somehwere where i would be able to connect my mp3 player, hopefully there is room somehwere. Anyway, any help would be greatly apreciated. Thanks!
Username: Illuminator
Post Number: 641
There should be clips on both sides that you have to push in using a flat-head screwdriver or possibly even your hands. Then you can slide it out of the metal sleeve.
andrew00
Any chance there is a picture of this anywhere?
Post Number: 647
Very likely, though I haven't seen one...
