point me Unregistered guest |
Posted on i still have 110 and 119 but now that 91 is done what bird should i aim it at? Is there anything else worth while up there? |
compost Unregistered guest |
Posted on i think you can pick up T5....not sure of the channels |
chicago Unregistered guest |
Posted on go to www.lyngsat.com and check out the different satellites and channels on each yourself...then make own decisions. |
