96 probe SE wires
96 probe SE
got the speakers connected, but can't find power and ground (those are the only other two that will hook up to my new stereo it apears, theres others, but i dont' think they're used)
the harness is mounted and 2 feet in, no way to get to it, so i just need to know which of the following is the ground and battery (on the wires from the stock head unit, top to bottem)
blue w/ red stripe
green w/ red stripe
blue w/ white stripe
orange
space
thick black w/ gray stripe
space
red w/ black or green, can't tell
the other wires coming out on the other output area on the back of the head unit were all speakers, + - + - all the way down, all 8, so it's gotta be two of those above....
great_king_rat@cox.net
(subject " ****** " or else i'll think it's spam)
Username: Illuminator
Post Number: 631
http://www.streetdreams.com/wires/ford/general-1993-98.html
