heeeeeeeeeelpppppp meeeeeeeeee Unregistered guest | Ok, i'm going with one of these two set ups what's better..? I could get two 12" Rockford fosgate P312D4 which go at 500W rms with two MTX MXA6001 amps, 600W rms each. or i could get Two Alpine 12" Type R's with the alpne amp that gives 1000W RMS (1% THD) The alpine subs also each go at 500W RMS but.. will that amp the mrd-m1005 power the two type R's??.. i might be able to match the MTX amps with the two type R's. what's the best set up??! thanks!!! |
Silver Member Username: ThrushdtdNew York Post Number: 110 Registered: May-05 | the alpine amp is not 1 ohm stable so you would have to get the dual 2 ohm version of the subs. I have not heard good things about alpine amps but have heard great things about mtx. good luck. |
New member Username: AdamalpinedupPost Number: 2 Registered: Jun-05 | i have this alpine amp..... http://www.yourcarparts.co.uk/trolleyed/images/products/mrdm1000.jpg running a pair of 12" Alpine R-type subs (2ohm versions) see my prob thread lol cheers adam |
