This is about offroad lights. i'd appreciate the help
Username: Langless28
Post Number: 240
i have two 55w offroad lights. what size wire do i need to run to the lights. i think they draw like 10 amps max(110w/12v). im buying a 30amp relay too.
Post Number: 241
also what size fuse should it be a 10 amp fuse or a little higher
Username: Carguy
Post Number: 3287
That's a low current product. 16 - 14 gauge should be fine. As for the fuse, make sure it meets the maximum amperage of the lights. Unlike amps, lights will draw the max when turned on.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 7866
use 10awg power wire and you'll be fine for off road lights. that's what I use for my Hella 550 sets and they're 110 watt bulbs
