What you need for amp kit
Username: Dozyproductions
San Diego, California United States
Post Number: 33
since ive never done it or ever had a system before, i would like to know what you need for an amp kit. such as the wires and fuses and all that jazz. i think the only specs i have is that my mtx thunder942 amp needs a 0/1 guage ground wire and a 250 amp fuse. im think of just buying all the different pieces seperate because it seems like i cant find an amp kit for cheap that has an 250 fuse and etc. thanks-
WC
Just buy a 0/1 amp kit and all you need to do is replace the fuse.
Post Number: 35
and the fuse just use a anl one or wha?
WC
Depends, different amp kits have differnt fuse holders, if the amp kit has and ANL fuse holder and only 60 amp ANL fuse, just buy a 250 amp ANL fuse if there is any.
