Good Amp for 2 15" MA Audio subs
BanginBu
I plan to be getting 2 15" MA Audio MA1500XL subs which have 600 watt RMS and 1200 watt max each. First off... does anyone know about these subs? Also, what amp would you recommend for these subs. Preferrably an inexpensive amp so probably not PPI or JL. Any info would be helpful... Thanks in advance.
BanginBu
Anyone?
Username: Prankstar008
San Diego, CA USA
Post Number: 24
well i thought this would be a good match
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=79819%26item%3D5781402896 %26%26
but then I saw the 2 part. Although not the best, Xplod amps have a pretty good bang for the buck.
