New member Username: ShinjiPost Number: 2 Registered: Apr-05 | Is there one for less that $100 that has multiple inputs (at least 3) for both the component video and digital audio connections? Either optical or coaxial digital audio connections are ok as I can always pickup converters appropriately but it should have both. A less expensive version I found at Digital Connection if you can show me one. Please only places you have ordered from in the past. Anyone have any experience ordering from Digitial Connection before? Component (Y-Pb-Pr) 4x1 Audio/Video Switcher http://www.digitalconnection.com/products/video/1154a.asp |
MikeMitchel Unregistered guest | Check out the Video Storm CSW02. I researched this area a lot before I bought mine and found it to be the best value. It also has a dual output so you can use 2 displays (such as my projector and LCD). http://www.video-storm.com/proddetail.asp?prod=CSW02 |
TQ Chen Unregistered guest | Try this one: http://www.audioshowcase.com/catalog/switchboxes.htm Only $61.88. I'm thinking to get one myself. |
