Mistake???
Username: Lowfront
Post Number: 14
was it a mistake to buy 5 Fluance SV-6 bookshelve speakers??????????
Username: Nuck
Parkhill, Ontario Canada
Post Number: 90
Identical speakers offer a number of advantages.
Placement, timbre matching and spacial timing are so close, you have an advantage, especially in a difficult room.
For theatre especially, the 5 clones will take care of a lot of set-up questions.
If you liked a pair of them, you will like 5 even more, I bet.
I havnt heard these items myself, but the brand comes up often for good reasonably priced speakers.
Sounds like a good call to me.
Let us know. What receiver are you using, room size etc. and are you using a sub?
Cheers
Username: Stealth_c
Dublin, CA USA
Post Number: 240
If they sound like junk then yes; it was a mistake. If they sound good, then no; it was not a mistake.
So I guess the question is, how do they sound?
Username: Lowfront
Post Number: 15
im setting up a 7.1 setup
I went ahead and got 5 of those to start....
will that work or should i have just got three...for the front and center??
Username: Lowfront
Post Number: 16
well i just one a Harman Kardon AVR 235
today for 265....!!
and getting a STF-2 for a sub
Username: Lowfront
Post Number: 17
well i just won the bid........one a
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 726
If they end up sounding good, then having them all the same is a plus. No, five is better than three in that respect. Unless you would have spent the same cash on 3 better ones with the intent of adding more later.
So, if this is for 7.1 then what are the other two speakers? Will they be used as back surrounds?
Username: Lowfront
Post Number: 18
my rooms tiny by the way
sorry so many posts
Username: Lowfront
Post Number: 19
I dont know what they'll be for...let me know what they should be for...and what other 2 speakers i should get to finish...
just didnt have the money for 2 more speakers....
Post Number: 727
Man... That will be sweet!
I was writing the previous when you posted, so hadn't seen them.
Username: Edster922
Post Number: 783
David,
please post a review when you receive the speakers. Fluance does have a return policy but it's only like 7 days not the nice 30 days that Ascend and Axiom provide.
What I'd do if you're not sure how you like them is, take a pair of them (easy to carry) into a shop and listen to them with other speakers in the same price range.
Post Number: 728
David,
Start with a 5.1 system. The receiver will be happy to accomodate you. My back surrounds are OFF; I'm using 5.1 right now. No room for back surrounds.
Username: Thx_3417
Bournemouth, Dorset United Kingdom
Post Number: 248
Spot on now all you need is THX a few EQ active X-over units and your home free!
Username: Artk
Albany, Oregon USA
Post Number: 687
Enjoy your speakers David!
http://www.soundreproduction.com/reviews/Fluancesv6.html
This should help you with your buyer's remorse.
Username: Edster922
Post Number: 799
That sure is a nice little review...wonder how they'd compare against my horrible Polk R20s (bedroom minisystem) I bought for $80/pair from CC on Black Friday. Kicker is, CC used to retail them for something like $200!!!
Username: Lowfront
Post Number: 21
Thanks Art that did help with my buyers remorse...
Im feeling good now
Username: Lowfront
Post Number: 27
Andy what do you mean by
