Ok heres the deal, i have a samsung scd103 mini dv. well it came with Samsung DVC Media 5.1 and when i put it on my computer from that i cannot edit it in windows movie maker or adobe premier 6. The only way i can even view what i just put on my computer is to change the name to a .avi. even after i do that i cant edit it!! Please help!
jacob linzenholt
P.S. I am using a USB cord and cant use a firewire cord
Renzo
This will not work, you'll need a firewire cable, and a firewirecard in yur pc. Not expensive, so no reason in not doing this.Good luck
