Sony 60XBR950 or Samsung 6167?
smcgd
I am about to purchase but am caught between the two. I know there are differences in LCD vs DLP, however, at BB both looked great. I'm open to suggestions.
drago88
yeah, i'm choosing between those 2 also
drago88
ogbuehi
I would forego the 60xbr950 and go with the 60xs955. They provide the same pq but the xs has more connections (2 hdmi versus 1 dvi for the xbr) and is a couple thousand dollars cheaper than the xbr. You are paying the extra money for the xbr because of the anti-glare shield which is useless unless you have a really dark room. As far as the DLP vs LCD it's going to kind of depend on what you plan to do with your set (gaming, movies etc.) Each one has its plus' and minus'.
