so there is no way to run them off my mono amp along with the subs? if i run two amps, wont that drain my battery?
capww8
no, it won't drain your battery... unless you're running your stereo w/out the car on... in which case one amp would be too much.
ditto david's comment... it would be really ridiculous to try and run two subs + two speakers off one mono amp. It can be done, but it would be really dumb.
