MAKE MY 6x9's WORK. PLEASE HELP
Username: Ianfrid
I am very new to car audio, and have purchased some Pionner 6x9s and a Sony Xplod headunit (I know u lot don't like sony, but it will do). The wires from the 6x9 are just normal speaker wire with no connectors.
In the back of the headunit, there are 6 phono (rca) female sockets which all say audio out. There is also a socket with loads of different coloured wires coming out. Now where do I have to put the wires of the speakers.
I bought some phono (rca) male sockets and soldered the speaker wires to it and plugged them in the 6 different sockets, however when I turn it one, no sound is heard.
Should I be attaching the speaker wires to something else.
HELP
Cheers
Ian
Username: Illuminator
Post Number: 448
Jojo's advice in the post you made in the headunit section is probably what you're looking for.
