JL 12W3v2 sub/amp prob?
Username: Makenx19
ok I have an Auidobahn A8002T amp and im plannin on getting a JL 12W3v2 to run in a ported box. my question is this the amp runs with an output like this:
200Wx2 at 4 ohms
400Wx2 at 2 ohms
800x1 at 4 ohms
now i now the JL is rated at 300W RMS but is that total or for each voice coil. and i need to know whether i shoul run it mono (since the wattage has a 99% chance of being overrated and is prob 600Wx1 instead or 800Wx1) or do i sell the amp( and my other Infinity sub) and get a CEA compliant amp rated at 300Wx1(if sub is total 300W RMS) or 600Wx1 (if both coils can take 300W RMS)srry if this is long winded but i dont want to void JL's strict warranty. thanks in advance
Username: Kenny_hammond
Post Number: 95
i had 2 12" (W3's) hooked up to a pioneer 760 in series and it pounded i had them in a seald box now i am tryingo put them in a prted box but i cant find them on the nt can u help me out?
Username: Insearchofbass
Post Number: 2477
they are rated 300 rms total (150 a coil) but will take more if given clean power...clean being the key here
Username: Makenx19
so if i could sell the amp (maybe 150) and my other sub (50 prob) wut would u recommend then>
Username: Makenx19
Post Number: 7
if i could get 150 for amp and 50 for other sub i could sell wut would u then recommend?
Post Number: 2479
use the 12w3 they have excellent sq do 2.00 cf sealed and drop it in
Username: Makenx19
Post Number: 8
so the "800W" wouldnt kill the sub in mono? ( if it really is 800W)
