Archive through May 30, 2005
LK
The pansat 2500 is a very good receiver without some of the frills,but very dependable..what was added was an autoroll bin which automatically changes the keys data when dishnet changes them..
If U have some channels still from Dishnet,then its not a changing of the public keys problems...try rebooting it (Back of receiver,power OFF,wait 1 minute,power ON) now change the channels, and maybe scan the satellites again..U need to do much reading for a couple days to learn the programming..go to www.al7bar.TK newbies area for help and manuals..
eral
LK or anybody help with keycodes on FTA why thay not working single is good and channls are in still have no picture just downlaoding data & plaese inputdata thats it?
Username: Keira
North bay, Ontario Canada
i am going to leave my e-mail because i need serious help genevieveromain@hotmail.com. please help
ron10
new codes anybody please!!!!!
Merenwen N.
anyone have new codes??...Im in serious need of some keys...
Username: Maple_leaf
Post Number: 252
Already posted a dozen times look around
maple it may be posted a dozen times in another site, no active keys are posted as of right now. The keys posted are no longer working, if you know of a different site with the info please share with me as I cannot find the dozen postings with active keys....
Post Number: 254
Posted on Monday, May 09, 2005 - 04:04 pm:
KEY0 B4 1C 14 6C F2 31 0D 2E Active
KEY1 8A 3B CF 2F 19 8D C8 CA
09-05-05 14:54:21
Boozilla
Anyone know where to go to get the keymaster program? Heard about it and can't find it.
rtgrtre
boozilla
this is the site for you....
http://www.maestra.tv/keys/
LK
keymaster.exe is located at the File Share FTA area at www.dsscommunity.c o m
eral
new keys are working?
Username: Douglas2005
I have a question that may not be possible. I have an extra DTV RCA receiver. I would like to change the serial number so that I can use the same card in two receivers. The card is married to receiver1 and I want to clone the receiver so that the card won't know the difference. It is for convience so that I can take my card and service with me without toting around the receiver.
annoymous
I've been having a problem with my Pansat 2500A. My satallite echo 8.6 is not working properly. Does anyone know how to fix the problem. I've entered the code and it has worked for a while, but I do not get all of my p a y p e r v i e w channels like I used to.
LK
Douglas...NO way Bud!
anon...rescan the satellites...and N2 for many PPV's now
panic
all my channels are not working
help
Merenwen N.
Thanks Maple Leaf
Merenwen N.
Thanks Maple Leaf
My tv says no signal
LK
turn it on..and align your dish
jdogg_33
new key - codes please????????????????
Hi guys!
New key for Dish Network
Key01: 0B 27 EC 1E A8 B9 2B 0A
Enjoy
urbabe190
NEED CODES......ASAP............TY
urbabe190
Richiepooh
KEY0 6a cf 0c 39 11 e7 42 60
sexygirl6996
new code plzzzzzzzzzzzzzzzzzzz
Username: Masaniello
Naples, Florida United state...
hi lg can you tell me hats up for the italian ch.639 on pansat dish net the move to to nagravision 2 ? please repond me thank you sal
LK
How to change Dishnet keys: 00 or 01
Pansat receivers................
press menu
go down to parental controls, and press OK
press down arrow and enter 0000 thats 4 zeros
now go down to nagravision and press ok
now press the right side arrow next to the ok button 11 times until it says dish network
now press the down arrow 1 time
key number should read 00 now
using the buttons on the remote (number buttons, To type the letters into the new keydata, press the appropriate button on your remote: Audio = A, Info = B, Signal = C, Pause = D, Sat = E, EPG = F)
set the key to whatever the latest key code is
8A C4 96 93 EC 79 9D 57 ....(example only)
now press the ok button!
then press exit 3x to exit the menu
Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset
This is how to change your public keys when needed, these instructions should work for both 2300 and 2500 pansats.
Fortec key change method
1)With receiver hooked up to TV and satellite:
2)Press MENU on the remote control
3)Then right side arrow to CHANNEL EDIT
4)Go down to CODE, and press OK, and enter 1010 (could also be 1668 or 1688)
5)Then right side arrow to turn OFF, KEYCODE FUNCTION
6)Go to NAGRAVISION and press OK
7)Now press the right side arrow next to the OK button 11 times until it says ((DISH NETWORK))
8)Go down to KEY Number, then right side arrow to set to "00".
9)Go down to Key Data and enter the latest KEY with your remote control.
D5 6F BB 83 00 D8 B0 4E ...(example only)
10)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "00" is saved.
11)Go up to the Key and Go to the right "1 time" (that will change key 00 to 01
12)Go Down and enter latest Key 01 change ..11 B1 AA A7 8B 9E 45 8B (example only)
13)Press OK, "you will see the STORE button blinking, when it stop you know that KEY Number "01" is saved.
14)Press EXIT once.
15)Then right side arrow to turn Code back "ON" and enter "1668" then EXIT, EXIT.
16)Lastly, on BACK of receiver (not remote)..power OFF,wait 1 minute ,power ON..this is a reset
Fortec buttons to use for letters
Sat=a
info=b
tv/radio=c
pause=d
?=e
KEY0 6A CF 0C 39 11 E7 42 60 Active...changed today Thurs 12 May
KEY1 0B 27 EC 1E A8 B9 2B 0A
12-05-05 13:05:12
hello LK I was write to you yestday i put wrong letter instead lk was lg sorry can you tell me wat up for the ch 639 rai the moved in nag 2? the you thing cam up some n ew for see the channel , thank let me know sorry for my english writting SAL
PANBA
CAN WE GET TNT OR/AND ESPN FOR NBA PLAYOFFS ON DISHNETWORK?
LK
READ....U might learn your answer..we lost all the baby spoons here,so cannot spoon feed anymore..
sexygirl6996
hey new codes
Post Number: 278
KEY1 95 29 19 8E 6E 76 FB C8 Active
13-05-05 16:57:09
My Pansat 2500 gets only verticle but not horizontal channels, everything else is working fine. Any suggestions?
Just George
It would be my guess that you are using a Dish Pro LNB.The easiest way to solve that problem would be to use a dish pro channel list which you download using Gtools. The dish pro list already has the Horizontal and vertical transponders changed to vertical only, thereby allowing you to receive all of the available transponders. There is a way of doing a sat scan and changing the transponders yourself,but it requires a bit of calculations on each transponder.I would not attempt to tell you how myself,because of the complicated nature.
hey lk PLZ HELP M I M USIN FORTECSTAR LIFETIME..WHILE DOWNLOADIN SOFTWARE IT GOT HANGED AND THEREZ NOTHING NOW JUST THE YELLO LIGHT ON RECIEVER DISPLAY..
TEL ME HOW I CAN FIX IT?
Username: Cut177
IslamabadPakistan
TEL ME HOW I CAN FIX IT? pz tel me was it da flash rom which got damaged or wat?
Username: Jmill1948
Chester, Va Usa
Post Number: 651
moshin try to reflash it with the factory bin file see if that works then load the latest autoroll bin file check out al7bar.ok change the o to a t
bummedout
LK I have a fortecstar and expect it to be useless when Nagra2 is the norm. What card can I buy on ebay that will give me the nagra2 channels?
LK
None..U must SUBSCRIBE!
da_dragon
hey today i turned my tv on and the pay per viwes and the hbos dont work what i can i do or is it like that now?
da_dragon
now the code doesnt work what happened ?
LK
KEY0 12 36 3A 6F D8 F4 BE 6A Active
16-05-05 15:02:56
da_dragon
i have put those in but it doesnt work
i have the pansat 2300A
da_dragon
whats going on its not working :-(
LK
Then U're shouldn't even own an FTA!...anyone who can't flash/load an autoroll bin or manually enter Dishnet keys should SUBSRIBE to cable!..the keys work fine,its you!
try a reset of reseiver (Back of receiver,power OFF,wait 1 minute,Power ON)..change the channel...rescan the satellites if necesaary..
BTW...If U're talking Bev,not Dishnet,then PPV and movies are gone forever to nagra2 (MUST SUBSRIBE TO RECEIVE)..and Bev keys have NOT changed..if U're talking Dishnet,U should give it up!
da_dragon
im giving up looks like it that sucks lol
anything that i can do to get everything back
MylkyD
Thanks LK
LK I HAVE THE PANSAT 2500 THE MIDDLEEASTERN CHANNEL ARE WORK BUT THE HBO,PPV,STARZ ARE NOT WORKING CAN YOU HELP PLEASE
LK
are any channels working?...U using Dishnet or Bev?...have U changed keys today?...do U have autoroll?...did U do a reset?..do U rescan the satellites again?...what birds do U get?
sexygirl2169
new codes plzzzzzzzzzzzzzz
sexygirl2169
Codes PLZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
ANy one plzzzzzzzzzzzzz
jasonone@usol.com
LK AM USING DISHNET I HAVE ENTER NEW KEYS TODAY I DON'T HAVE AUTOROLL (HOW CAN'T I INSTALL AUTO ROLL) I SCAN SATELLITES BUT MY BE I DID IT WRONG TELL ME HOW TO RESCAN CORRECTLY AND I HAVE 69,110,119 FOR BIRDS THANKS!!!!!!!
what are birds ? ? ?
ninmar
ninmar
LK
U idiots sexygils that have been asking for the new codes/keys...they're posted above here and everywhere in these forums...its people like U that ruin these forums...either READ wwww.maestra.tv/keys or get the keys from the keymaster.exe file,or install the autoroll bin and never worry or ask about the keys ever again...many sites have policies were it is NOT permitted to post the new keys ,cause it makes people lazy and annoying like U!...I suggest we all do the same here in these forums..
NEVER POST THE KEYS/CODES again here in these forums!
dorita
nooooo !!!!!! please dont stop posting rhe keys !!!!! my computer is broken so I dont have any other way to get my beloved pansat running.
come on guys !!!!
bummedout
LK so the cards that people are selling like the one in this add http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5773904646&category=32845 &sspagename=rvi:1:1v_home is no good? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=32843%26item%3D5773873901 &tc=photo
Just got my Pansat and its not working I have been to a couple of sites mainly thedishguy.com and got alot of information and donwloads for the pansat 2500a but reading through the instruction, it ask for a gtools1.85 program but it say that it is courpeted and I am unable to use it. I would be very thankful for any help anyone could provide. I do have the website for the key codes but it seems that the all channels includeing ppv and adult are not working whats the deal. thank you
LK
Dorita ...U are full of BS...U need the computer to enter the keys manually!...and with autoroll U don't need the computer to change the keys ever again!
Buddy..just flash the 246 autoroll bin with STB updater (many times its in the .zip file with the 246 file) then do a reset (power off,wait 1 min,power ON BACK of receiver),then U don't ever need to enter the key codes...U don't need Gtools either,only for loading channel lists which U don't need to do ,if U do satellite scan instead...adult channels and most PPV's are gone to nagra2 forever..whats nagra2?...read this www.nagra2.org
LK
bummed.. NEW VIRIGIN Dishnetwork Yellow Cards *****NAGRA2...they are NO GOOD,they have not been hacked yet...here's why...www.nagra2.org
why have we lost adult channels with maestra keys?
Mexico Mty
ill try to write a bin in my 2500a, but it don't let me. This error appears : WRITE FAILED (ER1). What can i do? could you help me LK?
urbabe190
NEED NEW CODE MI TV IS DOWN.......THANX IN ADVANCE :-)
urbabe190
Ron10
CAN ANYONE BE SO KIND AND POST THE NEW CODES PLEASE I WOULD APPRECIATE YOUR HELP THANK YOU.
GOD BLESS YOU GUYS.
Username: Sall
Post Number: 8
Hi Guys!! New Keys!!
01
02 4D 58 19 8C 3A C5 C4 ENJOY!
Username: Sall
Post Number: 9
01
urbabe190
I HATE THIS TV ITS DOWN AGAIN I NEED A NEW CODE......ASAP THANX
LK
Get the keys yourself....www.maestra.tv/keys better yet,get the keymaster or getkeys file and NEVER have to ask again or search for the new keys..or best install the AUTOROLL bin..
LK
Get the keys yourself....www.maestra.tv/keys better yet,get the keymaster or getkeys file and NEVER have to ask again or search for the new keys..or best install the AUTOROLL bin which will automatically find the new keys and install them for you!..
eral
to do the autoroll how do you download the bin into the FTA re.i have downloaded bin in my computer and typed the bin file in the browser lost after that help??
Maxito
LK: I have a Pansat 2500a (i guess ur tired to heard that)... I don't read, I want to know what i need to downloead, from where, and then once i conected, what do i do. How do I find the autoroll.bin, and does it work in the pansat or it finds the codes online?
PS: I have already GTRom Loader v3.32.exe and Pansat 2550_A_050401_235_api(N).bin ... are these useful? Got them from pansat.us
PLEASE, Help me LK
LK
Read the threads about "AUTOROLL" or "How to install the autoroll"..time to start reading and posting in the correct threads...everything is too scattered here..
deft
just me or did a grip of channels just go bye bye? :-)
u don't need keys
these are the latest firmware
X-75BL_050314_236cE_api------for pansat 2300A
X-85BL_050405_246_api----------for pansat 2500A
X-85BL2_050330_245_api--------for pansat 1500A
X-87BL_050519_105_api----------for pansat 2700A
X-95BL_3033_2005_0425_api--for pansat 5000HC
they all autoroll. and the 2700a has a working (epg)!
bronxbaby
can someone help me, i had all the hbo's, ppv and all the good channels, (fortec)then 1 day, no signal now all the channels are canadian channels and i live in the bronx, new york. what went wrong?
toronto baby canadain
FIRST OF ALL U SHOULD THANK GOD, HE GOT U OUT
OF THE BRONX, DON'T TAKE IT WRONG, I LOVE THE
U.S.A. BUT LIVING IN CANADA TORONTO IS MUCH,
MUCH BETTER THEN LIVING IN THE BRONX! COME ON
brother, U know I'am right. Just think U can
get "CITY.TV and all these wounderful canadain
channels. Set back and injoy it brother and sister.
Username: Jderek
Post Number: 25
hey Bronxbaby...your sat dish moved..what sat were you on before because the Canadian sat is very close if you were on 110..Yankees rule
Biver
must have moved a lot to the left and then moved up. not close at all.
Aya
Hi everybody !
I want to know why I can't receive chineses channels ? Are they close ? Because I receive only American channels !
Sorry if my english is not good >_<"
I just started using the Fortec Ultra and this week noticed that some of the arabic channels from Dishnet are starting to disappear. Could somebody please explain why this happened and how I can get them back.
LK
Read the RULES here...then read the thread "nagra2 and International channels..
snarf818
nagra2 i think has been hack theres a new receiver on ebay for 1.926.00 dallors its call the black bird dream box no#p5 eney body email me if Iem righ
snarf818
Aya
Hello
Sorry but I don't know what it is nagra 2 ?
I've this in Pansat 2500A ? if not , how can I have this ?
Thanks in advance !
LK
this is nagra2....www.nagra2.org ...OBVIOUSLY U don't read and have NOT made ANY effort on your own to learn...so please don't bother us here...no more spoon feeding here!
BTW...I believe these type ridiulous posts are done purposely just to bust our chops!...and there are many,so I put these in with the "ignore the jerks" catagory..
Aya
I'm sorry if i've bother you but i'm not here to bother you , I wanted just that you help me, because I'm not english , I'm a french girl and I don't very understand too much data processing!
I saw in the nagra2.org that that spoke about cards, in my machine does not have there the card, what I do have to make?
And I want to know , what it is FTA , Atmega, AVR or Rom 2,3,10 or 11 ?
Thanks
LK
I'm not buying that poor little innocent french girl act...Go READ like everyone else kneegrow!...I'm all done talking to you (kneegrow)..go hook another fish..that mental ward allows computers huh?...surprised!
Aya
ok, I will read, read, I thank you for having answered me! :-)
eImo
another one bites the dust.....
Aya
By the way , what does it mean " kneegrow" ? Because I sought in the dictionary and I didn't find!
Aya
Sorry >_< , I know now LOL !!
I had not seen
BigDickDADDY
for all yall having trouble with the pin code not showing up ******you must do a sat or blind scan first! then the second pin entry will show up. real simple, but can be a problem if your too damn anxious to get the free channels!
i HAVE A FORTEC ULTRA AND DOWNLOAD AUTOROLL BUT ALWAYS FAIL WATH CAN i DO
mr.hardon
BigDickDADDY
Just maybe U are what U say U are, but I
have no doubt about U having brains. I would
say little to none. So why don't U put a
french-safe over your head and U will look
like the DIICK U are. "COME SHOT".
i heard on the radio today that BEV is all done JULY 1 how long for Dishnetwork?
