Hey Jonathan, I may end up checking out the DD 3500 series but not sure if i want the 12 or the 15". I will be pushing it with a CrossFire VR1000D amplifier which does 1000 x 1 @ 1 ohm rms a 12.5 volts. I emailed DD just now but are you familiar with the 3500 series and how it whould compare to my Avalanche 15 and my JL 12w6v2 ?
Thanks jonathan, i got your last post on the other thread. So even the DD 3510 will have more SPL then my Avalanche 15 huh ? I was thinking about the 12 or 15 but not sure yet. Also what kind of box is best for these?
The 10, I doubt it, I meant for equivalent size. Forgot to point that out, sorry. As far as box, ported is the way to go for them. They don't do well sealed. DD has specs on the enclosure to use.
