IS IT OK TO CONNET 8 SPEAKERS TO A FOR CHANEL AMP?
Username: Junior11124
NyUs
Post Number: 17
OK . THE SPEAKERS R 4 PIONEERS 6981R 4 OHMS AND 4 INFINITY KAPA 6.5 . CAN IT ALL GO ON 1 AMP , THE AMP IS THE KICKER KX600.4 AND IT STABLE AT 2OHMS IN EACH CHANNEL. SO WILL 2 SPEAKERS ON EACH CHANNEL BRING IT DOWN TO 2 OHMS ?
Username: Illuminator
Post Number: 414
Yeah, it will be fine.
NyUs
Post Number: 18
Are you sure thats not going to harm the amp? I just don't want it to over heat. Can anyone else give me their opinion? pls
NyUs
Post Number: 19
Username: Lilsherm51
Johhnstown, PA US
Post Number: 14
ya ull be fine--as long as all the speakers are 4ohms, each channel will recieve a 2ohm load, which your amp is stable at, it should be fine
NyUs
Post Number: 20
oh ok thanks
