Box help.. a few questions
Username: Shawnomak
HB, SK Canada
Post Number: 38
Im building a ported box with square vents on the sides. there is a divider between the subs so its like 2 seperate boxes. i'll have one port on each box, the enclosure volume is 2.1ft cubed each. the vents are 3.5" wide, 14.5" high and there is a corner in the vents so they are each 29.4" long. i think this is tuned to 42Hz. Does this all sound right? will 42 Hz sound good and be loud?
Username: Insearchofbass
Post Number: 2022
you are right 42 hz but the fact that there is a corner (if by corner you mean a 90 degree bend) will actually make your port tune slightly lower. Plus the fact that your saying the box is 2.10 cf. internal gives the assumption you have accounted for port and subwoofer displacement otherwise your internal air space will be less and your port tune higher as a result.
Username: Shawnomak
HB, SK Canada
Post Number: 39
how much should i take away for port and sub displacement?
Post Number: 2049
ill see if i can find you an article on the subject ok
Post Number: 2050
read this ok
http://www.caraudioforum.com/vbb3/archive/index.php/t-97333.html
Post Number: 2051
heres another good article that may be easier to understand
http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=11;t=060743
Post Number: 2052
copy and paste the link in another window if it doesnt work.....keep reading and reread if you have to and do the math along with him and youll get it ...it might be hard to understand at first it was for me
Username: Shawnomak
HB, SK Canada
Post Number: 40
thanks for all the help man.
Post Number: 2059
your welcome
Username: Shawnomak
HB, SK Canada
Post Number: 42
any idea of what db i can hit with a nice box tuned to 42Hz with 2 Infinity 1230's?
Username: Shawnomak
HB, SK Canada
Post Number: 43
any idea?
Post Number: 2209
depends on alot of things they will be loud enough for you with decent power to them. What amp you drivin them with?
Username: Shawnomak
HB, SK Canada
Post Number: 44
an Infinity 310A
Post Number: 2259
from what i see that amp is only 4 ohms stable at max power if so your two infinity 4 ohm single coils will only be able to go 8 ohms bridged and 4 ohm bridged is only 116 watts rms according to the one site...do you have the literature to check if its only 4 ohms stable mono
Username: Saustin1988
i r sean
Username: Shawnomak
HB, SK Canada
Post Number: 45
if i run them in parallel its a 2 ohm load. that amp puts out like 200 and sum watts at 2 ohms
Username: Shawnomak
HB, SK Canada
Post Number: 46
the 310a is 312W rms at 2 ohms, sorry
Post Number: 2263
honestly dpending what type of box you get and cabin gain youll prob be in the low to mid 120 db's i metered one off of a bazooka 500 watt amp i think in a about a 1.5 cf sealed and it hit 126 db in a honda crx i think but they have good cabin gain
Username: Shawnomak
HB, SK Canada
Post Number: 47
yea, i like my subs. I wanna amp my speakers asap so i can turn the bass down and have the lows coming from my subs. my car rattles kinda bad tho so i wanna fix all that up. Im gonna use foam or somthing.
Post Number: 2268
you could try that fatmat or edead not sure of the price
Username: Shawnomak
HB, SK Canada
Post Number: 48
yea, could go with that. what does that do btw, just stop rattling or does it have other purposes?
Post Number: 2273
stops rattling and in turn increases your spl in most cases
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 150
is this the sean/shawn thread lol
