DishNetwork Keys for Pansat & Fortec as of 04/15/05 @ Time 15-04-05 5:27 PM EST
Username: Iamcanadianwdsk
ONT CANADA
Dish Keys
Key0 79 B9 9D 5E E6 BE E7 60
Key1 44 D5 4A AC DE CB 77 A7 Active
Yours Truly
DUCK
Username: Knee_grows_back
Post Number: 585
yea..thanks idiot stick...like I havn't seen them already on 20 other threads...fcuking moron
l AM Canadian
IGNORE KNEEGROW......ITS THE ONLY WAY
Username: Thechiz2
Shallotte, Nc Us
hey, i have 119 the signal is at 99 and quality at 90 i enter the keys as of 4-16 i scan echo6.8 the channels show but it just says waite for picture. and nothing. i am using a dishnet sat it's an older one can anyone help i've red till my eyes burn. i also have all the flashes and auto rolls up to date im using pansat 2500a
Username: Thechiz2
Shallotte, Nc Us
ok i got 110 in yes im a newb but i do read read read. i thought i had 119 but i have 110. some of the channels have a week signal though oh yeagh i got it working with a channel list. any pointers on getting 119 ?
Username: Jderek
Post Number: 22
119 is 1 inch to the right of 110 but its elevation is a bit lower. Find a channel that is on 119 on your channel list..hit signal button the remote and go outside and move your lnb till you get 90% signal strength. Make sure you run the coax cable straight from the 119 lnb to the receiver no switch till you find it. LK's instructions and it worked for me.
what's the new key?
Username: Racoon
hi every body,
I`m looking for keys for dish network, I use a pansat. Before I used dishnewbies.com but know it`s not free any more, and I can get in. If someome could help me, it`ll be realy helpfull
thanks in advence
LK
https://www.ecoustics.com/electronics/forum/home-video/135720.html
new york city
Hey Lk You have always been a cool and very informing dud. I recently lost my dishnet network channels but rescanned the frequencies and now got channels from bell express vu. I do not mind the channels because I have been able to get eastcoast channels. i would like to know if you have any information on the eastcoast channels for bell express vu. I do know that the beam is coming from canada. If you have any info I would gladly appreciate it.
new york city
LK
Bev is just about dead cause of Nagra2 (so why bother),and why not get Dishnet instead!...align roof dish to the 110-119 birds,while on a Dishnet channel,then load up an autoroll bin, scan those birds, reset receiver, and watch TV..
new york city
Okay No problem I will follow your instructions.
But If I am correct I did not move my satellite's position.
new york city
LK
U did something different to get Bev instead of Dish..I don't know your roof dish setup or whatever,but either U realigned/aimed the roof dish or scanned the wrong satellites (Bev= 82-91) and Dishnet = 110-119..or need to check the disque swich settings again..BUT to now get BEV,U must have a roof dish aimed that way..Are U sure U know what U're talking about..
THE POSTMAN
THIS BAD BOY FROM NEW-YORK DOESN'T KNOW F*U*C*KING ANYTHING
HE IS LOOKING UP YOUR AZZ. IF HE GOT HIS HEAD OUT
OF YOUR F*U*C*KING AZZ-O JUST MAY-BE I COULD TEACH
HIM A FEW THINGS ABOUT THIS SATELLITE BUSS-------I KNOW THAT (l-k & mr.leaf & billy-boy think that they are smart, but let me tell you they are all stupped azz-000000000000000000000000
ignore the jerk
Kool Kat
lol man ...this postman dude is gettin stale
Username: Maple_leaf
Post Number: 277
Well that's ok his mom is back now. Time to go nurse.!!!
What is the new key PLASE
New keys for pansat 2500a please
LK
KEY0 6A CF 0C 39 11 E7 42 60
KEY1 95 29 19 8E 6E 76 FB C8 Active ...changed today Friday 13 May
13-05-05 16:57:09
Thank you LK!! I have rollover but something is wrong. Thank you again.
Username: Shawn_wicks
Waterford, Ms USA
LK, I have a big dish(8 foot)what do I have to do to get it up and running? It is a UNIMESH I
HAVE A 2500A
silica_storm
hey i have a problem i put in the code but it still says data is being downloaded am i supposed to wait?
yes!!!It will come up
What about that unimesh dish on a 2500a pansat?
sssss12
That same happen here I put in the code but no change; I tried many times, any suggestion
LK
READ about download...its NOT DONE...wait!
unimesh dish is OK,try a dualMESH DISH ITS BETTER!READ about various dishes and LNB's...it all depends upon what satellites and programming U want!...another DUMB question!
ssss12
I tried but it gives same thing bad channel, I tried to reset it and reenter the code, but it comes to same message " bad channel"
Any suggestion
LK
yeah...switch to cable
ssss12
Thanks for suggestion
LK,I do not no anything about this that is why I'm asking you for suggestion!! Can you help me?
I like to get nag2 and whatever I can get~PPV
LK
U want nagra2,then subscribe!..or switch to cable (no nagra2)...what don't U understand!
and its your own fault U don't know anything,cause the info is here if U could READ!
Let me ask U this...do U go to school or work everyday and expect "suggestions" from everyone on how to pass a test or get a job done?...or do U read before a test,or read everything U can about your job?
O, That the way you answer!!
miIo
stop the buIIshit and read this www.nagra2.org
New key PLEASE
new key for pansat2500a PLEASE
LK
KEY0 12 36 3A 6F D8 F4 BE 6A Active
16-05-05 15:02:56
LK
16-05-05 15:02:56
header108
LK.
The Keys that you show are not working on my 2-pansat receivers they had these keys in them whem they went down.
I redone the keys again with no luck I turned off receivers on the back for 5 minutes and no luck.
Any Ideas never had this problem before.
I have a older flash on them is there a chance that we have been hit with a ECM
LK
header...how did U have these keys in your receiver...they are new keys which just came out tday at 3:02 pm..why don't u use autoroll like most intelligent people and never have to worry about the keys changing..
reenter the keys again,then do a reset...what is your screen doing?...u provide no info..
joma
I understand that ppv is still on on dish, what would be wrong if you can get channels, just not ppv. (Pansat 2500a)
joma
I guess by all my reading, I must need to flash the receiver, so now my question is how hard is it to find this cable? I have checked stores online, and nobody seems to have female/female. I found them on ebay, but I would prefer to find it quicker, and not wait for shipping. The other question that I have about the process, when i do find the cable, is does the rec need to be hooked up to the TV at the same time. One set of instructions said it did, others didnt mention it...
Username: Jmill1948
Chester, Va Usa
Post Number: 652
joma the cables are all over the web do a goggle search...
header you need to go on and install the autoroll....you can do it.if you nmeed a copy of the file email me......................peace............jmill
jdee
anyone not getting rpti or spt and what may be wrong
jack7877
hey guys i got a pansat 2500a i have all adult chanels i can't see now like it said data is being downloading when i try to watch them but all others r fine can someone can help me with that.
jack7877
Post Number: 316
Yes look around for that thread about xxxx and ppv and N2 not going to post every where the same thing any more. And your in the wrong thread.
New keys PLEASE
LK
Read these rules...U will be enlightened
https://www.ecoustics.com/electronics/forum/home-video/137647.html
jclz
new keys plssssssssssss?????
LK
these are the latest firmware
X-75BL_050314_236cE_api------for pansat 2300A
X-85BL_050405_246_api----------for pansat 2500A
X-85BL2_050330_245_api--------for pansat 1500A
X-87BL_050519_105_api----------for pansat 2700A
X-95BL_3033_2005_0425_api--for pansat 5000HC
they all autoroll. and the 2700a has a working (epg)!
new keys PLEASE
read the rules
Simple Rules of the Dss Forums here at Ecoustics..
All decisions made by moderators or administrators are FINAL!!
No Flaming. We will not tolerate any flaming or bashing of ANY members, especially mods or admins. You will be banned.
Rules For URLs . Please no URL's (active www.donotdo.com links). They will be edited. Use of site names,but not active links are allowed...Use xxx instead of www.
These Forums do NOT allow any selling or buying of any items.
Do take disagreements to PM or Email. If you are involved in a disagreement with another member, resolve it in PM or email. You won't have a disagreement with a mod or an admin because of rule number 1!
Be courteous and respectful of others. Participate,be active,helpful and do share. ENJOY and USE, these are your Forums!
The following information is a good set of GUIDELINES for using these forums.
POSTING
What, How, Why, and Why Not (Help on the ways of posting in threads). Provide as much information as possible, the more the better. Be clear,detailed and specific. You will get more and better replies with help, if your post is clearly understood and stated.
Do not post the same question in multiple areas. This is especially true with newbies. Many times people will post a question or comment in one area, and if they don't get any immediate responses they go to another area and post the same question. Make sure to determine the best area for your question. Posting the same question in multiple areas will cause your POST to be closed or deleted by a mod or administrator.
Do not ask basic questions that have already been asked over and over. The mods/admins and other members hate it. It shows a total lack of effort. READ the threads in these forums first. This is where the "read, read, read before posting" comments come from. Many people have been down the same road, and now they give that famous advice, "read read read before posting".There are many threads, and in many/most cases your questions will be answered there previously. READ first before you decide to post a new thread.
Try not to post in the wrong area. This is something we see newbies do quite often. It's not the end of the world, but, just try to think about where your post should go.
Stay on the thread topic..questions not related to the thread will NOT be answered..Start a new thread, If you do not see your SUBJECT addressed in an active topic..Remeber there are ARCHIVE threads listed also at the bottom of the threads and Dss/satellite index page..Much info is there also..
There are No files posted here, use other recommended reputable sites for files..
If you want the latest Dishnet keys, use the "Latest and Current Keys" thread..
Enjoy!
LAST CHANCE
NEW RULES
-NO DORK ,HACK WANNA BEES MAY POST ANY MORE OF THEIR GEEK BLABBER.
-ALL WOMEN WHO FEEL THEY ARE STUCK HAVING TO BE GIRLFRIENDS WITH THESE DORKS MAY CROSS THE BORDER INTO THE U.S. FROM CANADA TO EXPIERIENCE WHAT REAL MEN HAVE TO OFFER
-YOU MAY NOT IGNORE POSTING WHICH TRY TO STEAR YOU AWAY FROM BEING A BIGGER DORK THEN YOU ALREADY ARE.
-THERE IS MORE TO LIFE THEN BUILDING A SPANK LIBRARY... TRY TO REAL THINK,IF YOU CAN,YOU MAY LIKE IT
-STAR TREK IS ONLY FICTION!!,REALLY!!!!
-UNTIL YOU ARE NOT A DORK,DON'T LOOK IN THE MIRROR,FOR YOUR OWN GOOD, JUST DON'T..
- TRY TO MAKE A FRIEND OR TWO IN REAL LIFE AND YOU WON'T HAVE TO TRY TO BE COOL WITH THE DORKS WHO POST STUFF HERE.
THIS MESSAGE BROUGHT TO BY : GET OUT OF YOUR DORK RUT INC., HELPING DORKS LIKE YOU OBTAIN A REAL LIFE AND MAYBE EVEN A FEMALE FRIEND, FOR OVER 20 YEARS.
eImo
those rules are retarded
