Recommended power alternator per RMS
IangY
according this site (http://www.the12volt.com/info/recwirsz.asp) i should have a 120 alternator at least in order to handle a 800 RMS audio system.
I'm thinking about buying a 800 RMS kenwood amp to power my 2 12" subs. My alternator only works at 70 amps.
Should be enought to handle it ? What about buyin' a 1 farad capacitor, should it help without upgrading the alternator/battery. I just want to know if my alternator will work for 800-900 RMS.
Regards
Username: Illuminator
Post Number: 343
It probably can't handle more than 550watts rms at the moment and you still have to consider the car's other electrical components that require power.
Bottom line:The cap won't compensate for that much lack of power and the alt will have to be upgraded.
Username: Zootreeves
York, Yorkshire UK
Post Number: 22
Power (Watts) = Current (Amps) x Voltage
So 70A x 12V = 840W so should be ok especially as the voltage is probably higher (at 14V you get 980W).
But if you go over the RMS you may not get enough power and so could damage your amp/speakers so I would recommended getting a new alternator
Post Number: 345
Actually, the 840w needs to be divided by two. The 840w is max, not RMS. Also, most car systems use about 13.8v configurations rather than 12v.
Username: Carguy
Post Number: 3059
Your car may have 70A alternator, but more than half of that is used up by your car. So most likely you only have around 30A or less to play with.
A capacitor will only help as long as your power requirement is less than what it holds.
IangY
ok, i got the point, so if i don't want to waste money in upgrading the alternator, i should buy the 450 RMS one.
And as i read in other threads, a capacitor will only add extra load to the alternator in my case, so it wouldn't help anything ?
Username: Msully701
Stratford, Connecticut US
Post Number: 132
you need 15 amps every 100 watts of power
