Jl audio 500/1
Username: Jonklly5
Post Number: 17
is the jl audio 500/1 amp the best for the money. Im looking for 500-600 watt amp to power 2 w3v2's but i might not get those subs if theres something better for the price in them 2.
Username: Tdbdrummer
Post Number: 319
I've heard it's actually UNDERATED! Meaning...it puts out more no matter what it says. Also, those amps have RMS ratings for a large range of ohm loads...I wish I could afford a JL 1000/1...*sigh*
Username: Jonklly5
Post Number: 20
So you think its the best thing i can get for the money? What about something that zapco/Orion/PPI makes. I hear those r really good.
Username: Carguy
Post Number: 3033
You can afford an amp that's as good as JL if not better. Take a look at Orion XTR/SX/G4 series. PPI's PC/PCX are great too.
Someone is selling the Xtant 1001 amp. It is 1000w rms and can easily replace JL 1000/1.
Username: Jonklly5
Post Number: 22
Which one specificly that is comparable to the jl 500/1 near the same price.
Username: Carguy
Post Number: 3036
Well the guy wanted $600 for Xtant amp that was 1000w rms. JL 500/1 sells for $430. So for a little bit more, you'd get 2x the power.
Orion HCCA 250 G4 will out perform JL 500/1 amp at a lower price. It is .5 ohms stable in stereo and 1ohm bridged. Orion XTR has 400w - 500w rms model at half the price. PPI has PC/PCX series that is around 600w rms.
They are all priced below JL.
Try searching on eBay.
Username: Alias747
Post Number: 129
Go for this Xtant 6.1. It puts out 600w rms and xtant is usually underated. I mean, it puts out 100 more wrms than a JL 500/1 and is like $100 bucks cheaper.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5776590853 %26
Username: Skyliner17
Saint Paul, MN United States
Post Number: 153
go for the zapco reference 500.1 or the reference 750. i like my zapco 1100 better than my jl 1000/1. makes my subs sound better.
Username: Jonklly5
Post Number: 28
why would i want 1000 watt amps if i only have 500 or 600 in rms with my 2 12' jl audio w3v2's
Username: Jonklly5
Post Number: 47
Username: Suleman36
Post Number: 1350
Jon Kelly go for the JL 500/1 and you will be done.
Username: Carguy
Post Number: 3058
Jon, it's called investing for the future. With 1000w amp, you can always turn down the volume to get 500w. But with 500w amp, that is all you're going to get.
Username: Adampit
Post Number: 58
I am selling a PPI PCX 2125
Specs are :
125x2 @ 4ohm
250x2 @ 2ohm
500x1 @ 4ohm bridged
It is probably under rated. Email me if you are interested. Adampit@gmail.com
