What Gauge wire??
Username: Jaackdeth
Burnett, WI United States
Post Number: 83
I have 2 amps. one is a phoniex gold 501, and the other a hifonics 1500 mono for subs, is 4 gauge power wire enough for both? Or what should I be using?
Username: Alias747
MN
Post Number: 357
How much rms power is each amp?
Username: Jaackdeth
Post Number: 85
The Phoneix is around 60x4
and the hifonics is supposed to be at 1500@1ohm which I have it at!
Username: Alias747
MN
Post Number: 359
The hifonics you should def be running with 1/0 gauge wire. The pheonix gold could be run with 8 or 4 gauge, but I would say 4 gauge to be safe.
Username: Jaackdeth
Post Number: 86
So running a power from battery and then spliting them off right? Same with ground? Right now I have just 4 gauge running both amps!
