Building a ported box need help!
Username: Fastbastard1977
Lousiville, Ky Usa
Post Number: 121
i need a measurments on building a ported box for 2 1506t audiobahns?
Lousiville, Ky Usa
Post Number: 122
anyone!
Username: Byrumjr
Post Number: 243
What do you want them tuned at?
Username: Insearchofbass
Post Number: 2207
your in luck these things look like they spec out nice if you got the room.....what do you want spl or sq or mix
Post Number: 2208
well you got two choices this subwoofer will work in both sealed and ported sealed acceptable to me would be 2.8 cf. each before displacements ported 2.34 cf each before displacements ported to 30.3 hz in ported youll be about 3 db louder in the low bass region to 50 hz and close up to 55 hz but the onlty thing i dont like about the ported is what the accuracy will be like they might me a tad sloppy....your subs displacement is .47 so sealed would come out to 3.27 cf per sub sealed and 2.81 cf per sub ported
