Best high-end HU??
Username: Masse1369
Post Number: 25
i was looking at the:
nakamichi cd700ii
pioneer p9 or p860mp
clarion drz9255
eclipse cd8455
has anyone had any good or bad experience with these?
what would you buy? (too bad i dont have $6500 for the alpine f1 status with multimedia manager)
any comments would be very helpful, thank you.
Username: Masse1369
Post Number: 26
by the way, i was going to be using the new 07 cdt components but decided on the morel elate series with supremo tweeter instead for front stage. morel elate midbass for rear stage. dls ultimate iridium 15 subwoofer and tru amps and stinger wiring.
Username: Masse1369
Post Number: 27
btw, the premier p860mp seems to be a very good value for what you get.
Username: Jonathan_f
GA USA
Post Number: 3968
If you want the most processing capability, the Pioneer P9 combo is a great head for the money. Other than that, all of them are great units and will perform very similarly to one another, I'd probably choose the Clarion because of the 96khz K grade DACs, then the Nak or Eclipse. Whatever you like the look/feel of basically.
Khan1
Im getting a Denon head unit, it sounds real good, just try to listen to all of them see what one u like
yelnatsch517
Wow, I was just wondering why they those Clarions are being compared with the rest when it is more than twice as expensive? With that said, what would be the best one with a $600 budget (give or take $100).
