alright many of you know my previous post, well i went and bought an HDTV , not a monitor, its got the built in.. Im going tomorrow to buy the HD antenna... but i want to know how i actually get "onto" the channel .. somone told me about going to a channel, for example "4-1" instead of just channel 4, since -1 would be the HD version.. i read the manual and says nothing about how to do that.. so my question is.. No where in my manual does it say anything about the 4.1 or.. "4-1" can somone explain how i go about this because i want to watch a HD show tomorrow and wanna make sure i get it all set up... if i just run a scan thru the HD Antenna will it automatically just pick up the "HD" channel the (4-1, 4.1) version? or do i some how need to manually add that -1?
Peas
Patience grasshopper, buy your equipment first, ask questions later.
