New member Username: Arrap69Riverside, CA. USA Post Number: 2 Registered: May-05 | I have a 2002 Silverado and looking into purchasing the MTX THUNDERFORM SUB BOX W/ 2-10 SUBS (paying ~ $300). Is this any good and what might you suggest I run to it? My amplifier budget is $300.00 -Should I keep my Stock Speaker or replace them with something else? What would you do? Any suggestions? No hard feelings taken! Respectfully, Alex |
Gold Member Username: Taylor17Kopperl, Texas Post Number: 1847 Registered: Jan-05 | What are the subs spec's? |
Bronze Member Username: DarkseidPost Number: 20 Registered: Feb-05 | I think those loaded boxes are rated for 450rms |
Silver Member Username: Rob315Cuse, NY U.S. Post Number: 482 Registered: Jan-05 | i have 2 alpine mrd m501's ill give ya for $300....pretty much brand new(less than a week playtime) email me at rtc0420@yahoo.com...ill get back to you monday morning. |
Gold Member Username: CarguyPost Number: 3053 Registered: Nov-04 | For $300, you're not going to get great amps. If you're lucky, you might get JL 500/1 for around $330. Orion XTR/HCCA 250G4/PPI PC/PCX series might be your better choice. JBL/MTX/Audiobahn are the other alternatives. |
Gold Member Username: InsearchofbassPost Number: 2210 Registered: Jun-04 | heres a good one and i didnt look for the cheapest price but its in your budget and a great amp http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5776241546 %26 |
Gold Member Username: InsearchofbassPost Number: 2211 Registered: Jun-04 | another good one in your price range http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573%26item%3D5777409573 %26 |
Gold Member Username: InsearchofbassPost Number: 2212 Registered: Jun-04 | there are other 801d's on ebay cheaper but used |
Gold Member Username: InsearchofbassPost Number: 2213 Registered: Jun-04 | nevermind i see they are 225 rms each 10 so you dont need an amp that big |
Gold Member Username: InsearchofbassPost Number: 2214 Registered: Jun-04 | this one would work well for you $164 with shipping and insurance 420 watts rms in 2 ohm at 14.4 volts class d amp monoblock http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5776447700 %26 |
Gold Member Username: InsearchofbassPost Number: 2215 Registered: Jun-04 | my bad its $166 with insurance shipped |
Gold Member Username: InsearchofbassPost Number: 2216 Registered: Jun-04 | jl 500/1 for 310 shipped lightly used claimed mint shaped http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=79827%26item%3D5777074953 %26 |
New member Username: Arrap69Riverside, CA. USA Post Number: 5 Registered: May-05 | Both of Seans Suggestions: MTX 6500d and 801d are under my budget, which one should I go for. Will it sound okay for everyday use? All suggestions are greatly appriciated. ~Alex |
Silver Member Username: Loc_outPost Number: 223 Registered: Feb-05 | What's up Alex so you're from Riverside I'm from Santa Ana Ca. Both of those amp will work great and yes change your stock speaker you might want to get some Infinity's what kind of HU do you have? |
Gold Member Username: InsearchofbassPost Number: 2223 Registered: Jun-04 | alex those 10's only handle 225 rms right? if so you dont need an amp that big |
New member Username: Arrap69Riverside, CA. USA Post Number: 6 Registered: May-05 | Sean: 450 W RMS Power Handling. I kind of like your suggestion of the MTX 6500d (~$200.00) What is an HU? Please excuse my lack of familiarity with the abreviations. After purchasing these items; do you recommend me having a specialist install them? Is it worth the pay? ~Alex |
Gold Member Username: CarguyPost Number: 3067 Registered: Nov-04 | HU = Head Unit = your radio/cd player. If you haven't installed anything or don't have electronic background, then let a prof install it. It'll save you lot of grief. If you're going that route, then look for stores that offer free installation with system purchase. |
Gold Member Username: InsearchofbassPost Number: 2226 Registered: Jun-04 | ok as long as your sure thats not peak power per sub I dont wanna see you blow your subs |
New member Username: Arrap69Riverside, CA. USA Post Number: 7 Registered: May-05 | Peak Power Handling is 900 W. Do you think this set of MTX 4500 will make me a happy camper. The reason I am looking into this set is because I wanted to keep try this MTX Thunderform Box. It runs for ~300.00 and comes with these two subs. I will replace the front and leave the back as highs. Good Advice; I'll take into a pro. ~Sean; you been a big help. You too KK |
Gold Member Username: InsearchofbassPost Number: 2230 Registered: Jun-04 | i dont remember the 4500's beeing all the best but you can give em a shot i know the 5500's were decent. |
Gold Member Username: InsearchofbassPost Number: 2231 Registered: Jun-04 | i would sell you two mtx 8000 10s if you were intrested |
Gold Member Username: InsearchofbassPost Number: 2232 Registered: Jun-04 | brand new never used |
Gold Member Username: InsearchofbassPost Number: 2233 Registered: Jun-04 | i decided on going with other smaller speakers instead of the 10s |
