Two weeks ago I bought the Samsung HLP4663 even though I wanted something a bit smaller (plus I've read all the horror stories about the lamps). Now I wonder if I should return it and try to get the HRL4266? Anyone know of info or reviews on this set (which I believe is new)? Thanks for any guidance.
Helen: I read in the Samsung brochure that the 4266 is basically the set you have with a built in hdtv tuner and a cable card slot. If you have the 4663 hooked up and running, thhen those 2 items are basically of no use to you in your present setup. The 42 inch also does not have the fine pitch screen so picture quality may be not as sharp. I would keep what you have. My wife and I have a 46 inch and it seems big but shrinks over time . When you watch some really good HD shows, bigger becomes better.
