Dynamat. is there any thing else?
any ideas
question what else is there and cheaper I need to do a hole car
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 94
Edead $1.50 a sq ft
any ideas
hey thanks what about that glue stuff dose that work all that good?
Username: Kklagge
Post Number: 160
is eDead up to $1.50 a sq ft now? I got mine less than a year ago for $1.00 a sq ft....stuff works great though
Username: Monkey_man
Post Number: 74
If you wanted to just put it into a trunk, would the trunk kit take care of it or should i measure it out and see how much i need?
Pgh, Pa Usa
Post Number: 105
the cheaper 1 is a 1.00 the other 1 is thicker an its a 1.50
Pgh, Pa Usa
Post Number: 106
measure it get a lil extra
