I think i have a problem
Username: Ericclapton
i just bought a new infinity REF1211A amp and is rated at 1300 rms at 2 ohms and i got 2 infinity REF1242W subs. the subs have an rms of 300 watts each. i was wondering if there was a good chance that i will blow the speakers. is there anything that i can do? please help
Username: Fordpwr
Los angeles, CA Usa
Post Number: 241
just turn the gain down a bit
the gain or the input level, cuz i dont think it has a gain
Username: Araknid
BOCA , FL U.S.
Post Number: 538
The level imput is the gain. Tell me the impendance of the speaker and ill come up with the best way to wire it.
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='REF1211A'&Ser=REF&Cat=AMP
go here and look at the amp and the speaker outs, its kind of confusing
Specifications
MSRP U.S. $: $129.95
Power Handling, RMS: 300 Watts
Power Handling, Peak: 1000 Watts
Sensitivity: 93dB
Frequency Response: 23Hz - 400Hz
Mounting Depth: 5-1/16"
Impedance: 2 or 8 Ohms
Username: Araknid
BOCA , FL U.S.
Post Number: 540
So The subs are DVC 4+4?
your gonna wanna wire it like this
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=7&image.y=5&image=Submit
The second one down, that way you will get a 4ohm load and each sub will get 325 watts.
Username: Araknid
BOCA , FL U.S.
Post Number: 541
Im sorry the links not workin right just put in 2 woofers and DVC 4 ohm x 2 and it will be the second one down and it will be a 4 ohms load.
Post Number: 7
how will it sound?
Username: Araknid
BOCA , FL U.S.
Post Number: 542
wait a minute is this the same guy that was called like fairly new to this or somethin like that?
and sorry for the mistake it will be 400 per sub.
Post Number: 8
no, what kind of sub would u reccamend for my amp... 2 12 inchers?
Username: Araknid
BOCA , FL U.S.
Post Number: 544
https://www.ecoustics.com/electronics/forum/car-audio/137305.html
Read over this. And look at the problem we had with that amplifier.
Post Number: 10
that all didnt make any sense to me, it was very confusing lol
so what kind of subs would u recamend for this amp?
Username: Araknid
BOCA , FL U.S.
Post Number: 545
OK this what you gotta do, I read over it and now understand. Wire it the way i told you to one Block. It will slighty overpower the subs but it should be fine. Or you can wire each subs voice coils in series to get a 8 ohm load and put one sub on each block and it will be 200 watts per sub.
Username: Araknid
BOCA , FL U.S.
Post Number: 546
Um what kind of subs? 12 like you asked would be fine and DVC 4+4 with 400 watts RMS. Or you can use the ones you were gonna use.
Username: Fordpwr
Los angeles, CA Usa
Post Number: 246
I own the Infinity 1210a( i think its lasts year's or something) All I can say is that nthis amp will put a little over its advertised power rating. No bull sh1t.
Post Number: 11
so what do u recomend i do, i dont want to blow my subs, and i like what i got, and if i should get new subs, what should i get? 12 inches
also, thanks a lot for all of the help, it is greatly appreciated
Username: Araknid
BOCA , FL U.S.
Post Number: 547
Yes 12 inch subs are fine, Ok the simplest thing you can do is buy 2 12" single voice coil 4ohm subs with 400-500 rms and hook up one sub on each block.
Post Number: 12
hey, what is the differeence between dual and single voice coil?
Username: Araknid
BOCA , FL U.S.
Post Number: 549
oh man..... The difference is single voice coil subs have 1 voice coil and can only be wired 1 way and called SVC for short. and Dual voice coil subs have 2 voice coils and can be wired 2 ways and called DVC for short.
examples
DVC 4+4 can be wired at 2 ohms when the voice coils are wired in parallel and 8 ohms when the coils are wired in series.
SVC 4 ohm can only be wired at 4 ohms
SVC 2 ohm can only be wired at 2 ohms
DVC 2+2 can be wired at 1 or 4 ohm
now remember you can wire two subs together which is more difficult to calculate off the top of my head but an easy one would be.
2 SVC 4 ohm can be wired 8 ohm series and 2 ohms parallel.
