Buzzing noise
NJB1234
I hooked up my amp for my two rear speakers each 50 watts rms. when i turn on the car this buzzing noise comes from the speakers. They still play but it buzzes pretty loud also. I dont know what the problem is. They buzz louder when the car is on instead of just the battery. any help would be appreciated.
Username: Illuminator
Post Number: 250
It might be best to try a different piece of RCA cable and also make sure you aren't running your RCA cable closer than eight inches to the power wire. If all else fails, you can always buy a noise filter.
Check this out as it describes many different ways to remove noise: http://electronixwarehouse.com/education/accessories/aboutnoise.htm
