NAD T763 fan
Ramx12
I just bought a NAD T763 and I am wondering if the cooling fan never stops. It makes quite some noise!!
It never stops even if there is no input going into the amp.
Can someone help me ont his?
Tks
Username: Artk
Albany, Oregon USA
Post Number: 431
Welcome ro NAD AVR's. I'm afraid you'll have to get used to it or exchange the receiver for another.
Username: Dary
Sao Paulo Brazil
Post Number: 66
The fan never stops and shouldn't make any audible noise. Ask for a replacement!
BTW, what is your 763 S/N and/or manufacture date?
Good luck
Username: Diablo
Fylde Coast, England
Post Number: 99
The fan noise should be minimal - only faintly noticable when within a foot of the machine in a quiet room.
You need either a replacement or repair.
Username: Rock_bob
Hi Ramx12,
Due to the high current capabilty of your NAD T763, a few of the cooling fans will always run to maintain air movement.
Ensure that you have left at least 3-4 inches of clearance on the top of your unit and ensure that it is not on a soft surface that can impede air flow from the bottom where the 4 cooling fans are located.
As you incrase the volume the fans will increase speed to keep the unit cool.
If you are hearing alot of fan noise, your unit may have ingested some dust and is causing increased fan noise. Possibly a light vacuming of the bottom of the unit will correct this problem. Be sure to turn off the rear panel power before attmpting this.
In idle at low volumes you should barely be able to hear the fans.
If this does not rectify itself, contact your NAD dealer or NAD tech support (800-263-4641) for the name of a local service center to correct this problem.
Enjoy,
Rock Bob
Username: Dary
Sao Paulo Brazil
Post Number: 67
Rock Bob,
Are you from NAD support?
Dary
DaryIlha
Sorry, dumb question. I didn't read the other NAD threads before.
