Sealing a prefab ported box
Username: Dpaw20
FL USA
Post Number: 215
I got a prefab ported box tuned to 39hz and the lowest bass notes are so much weaker than the ones around the 45-50hz range (im guessing). If i sealed up the port, would it solve my problem?
Also, if somone gave you a prefab ported box tuned to 39hz, would you seal it up if you HAD to use it?
This will be a temporary fix until I get a new custom box.
Username: Dpaw20
FL USA
Post Number: 216
bump
Username: Dpaw20
FL USA
Post Number: 220
bumpin this simple question...
maybe its just the song your listening to
Username: Dpaw20
FL USA
Post Number: 221
bump...
Username: Dpaw20
FL USA
Post Number: 223
please someone answer this question, im sure all of you know it.
Username: Dpaw20
FL USA
Post Number: 224
somone answer this simple question please
Username: Subfanatic
Walton, Ky
Post Number: 3532
yes iw ould
Username: Dpaw20
FL USA
Post Number: 225
lol, thx. Just wanted to make sure.
Username: Dpaw20
FL USA
Post Number: 226
but what would you do if you had the choice?
Username: Dpaw20
FL USA
Post Number: 228
wow...somone please help
Walton, Ky
Post Number: 3574
i would take the carpet it off, replace the board with the port, replace the carpet
Username: Dpaw20
FL USA
Post Number: 229
replace the board with the port? You mean a new port?
If not, would it be possible? Could I add to slot ports in the middle and it work well? I want it to be tuned down to like 28-30 hz.
