Db q on 2 different sub set ups
Sammy Delgado
how many DB's will 1 15" atlas hit in a sealedbox?
how many DB's will 1 12" kicker compvr(2005 model) hit in a sealed box?
and how many DB's will 2 12" kicker compvr(2005 model) hit in a sealed box?
and how big of difference is the SQ between the kicker and the atlas?
Sammy Delgado
add the 15"(one 15") avalanche in the mix.....so how many DB's will that hit along with the others^^
Username: Invain
Michigan United States
Post Number: 2430
Sorry man, but there is no way in he.ll that anybody can guess how many decibels you will hit with any of those setups. I'd go out on a limb and say the Avalanche 15 will probably be the loudest. Other than that, anybody that tries to guess numbers or say which is the loudest is a moron.
Username: James1115
Wilton, Ct
Post Number: 2950
atlas 170 db's
Kicker-100 db's
avalanche 220 db's
I AM NOT A MORON NICK!
Username: Invain
Post Number: 2432
OK. Anybody other than James that tries to guess numbers, is a moron. (James is just senile)
Username: James1115
Wilton, Ct
Post Number: 2954
yup I am the only 25 year old senile person on this F'ing planet, or wait I guess I am 39 according to Nick the D!ck
Username: Invain
Post Number: 2435
You know I'll never let it drop. Just like you drove Hunter off this forum with his Rupaul.
Sammy Delgado
okay screw the DB's WHICH WILL BE THE LOUDEST.. lol im just looking for the way to get the loudest basically with all those set ups^^ I'm thinking the avalanche but it's a meere guess.. what do you think
Username: Invain
Post Number: 2437
that would be my meere guess as well
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 370
avalanche by far if u can do things half right
Sammy Delgado
so then doing thins half right would require what... haha im totally new to car audio and don't feel like getting a nice sub with a sh!tty amp n stuff
any suggestions would help for the 15" avalanche
Username: James1115
Wilton, Ct
Post Number: 2959
I recomend an avalanche with a good amp if you have access to ebay look for a orion HCCA 250g4 thats what I run mine off and it sounds fantastic.
Post Number: 371
if you build a box to the right size and build it nice and solid and get a good amp to match it .. sorry im not in too much detail im not in a good mood at the moment
