Anonymous | ok i dont have alot of money cause of school, but im needing some bass. i have 300 dollars to spend on subs and an amp, my dad can build the box so that wont cost me anything.I was looking at http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777%26item%3D5773210222 %26 for the subs and http://www.woofersetc.com/product.asp?0=362&1=363&3=2166 for the amp What do you guys think? Is there something i can get for about the same that will give me more spl or about the same? |
Anonymous | http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64571%26item%3D5773971351 & amps like this used on ebay is the way to go if your on a tight budget such as 300$, you can pick these up for under 100$ plus your 100$ for the sub( you can go more then that) and that leaves you more then enough for install and kit.. you can probably get 2 of those kickers and use that amp i gave you the link to pefect 800wrmsx1 at 2ohms-- your set up |
Anonymous | I actually only need and amp that can push 300 watts@2ohms since those subs are rated for 150 each |
Anonymous | those subs are pretty old although they'll do a pretty good job/ those new kicker comp vr(silver ones) you could get a pair for about 160 shipped/ with this amp costing about 100 shipped your up to 260/amp kit 20 bucks/install about 40 bucks thats 20 over your limit but im sure you'll be alot happier with this set up |
Anonymous | ok i will look at the comp Vr then |
Anonymous | you could also consider just 1 12/15" atlas from Ascendant Audio with a budget like that-- it would run you about 120 shipped/then a decent amp to run it at 4ohms with about 300w rms would cost you about 100$ of ebay(if you have no problem buying off ebay)thats 220 and you do what you want with the rest lol good install/go buy an amp kit from wal-mart n your set |
Bronze Member Username: Daddy_phat_sackPost Number: 25 Registered: May-05 | i was looking at those comp vrs and i think i may get a pair or two of those...... but i also need an amp and a wiring kit..... ne one wanna buy an american pro amp that doesnt work??? i dont no wats the matter with it..... the lights dont come on..... i may have hooked it up wrong or sumthin..... ill sell it for 50$ shipped if ne one wants to buy it..... it would help me out a lot :| |
