Decent amp for (2) atlas 12's?
Username: Drpthemc
Atlanta, GA USA
Post Number: 14
I was wondering if the MTX MXA6001 would be a decent amp for the (2) Atlas 12's = 2ohm load... the amp is around $250 doesnt seem that bad... but jw... feedback! thanks you guys!!
Username: James1115
Wilton, Ct
Post Number: 2919
yup should work great.
Username: Drpthemc
Atlanta, GA USA
Post Number: 15
:D... thanks... btw is that a decent price for that amp?...
Username: James1115
Wilton, Ct
Post Number: 2920
yeah thats a good price.
Username: Drpthemc
Atlanta, GA USA
Post Number: 16
i was just wondering because the circuit city around here is selling that one, because its the last one plus it was open box... and yea... i just needed some info on it...
Username: James1115
Wilton, Ct
Post Number: 2929
yeah it will work good for what you want man and that is a good price on it.
Username: Drpthemc
Atlanta, GA USA
Post Number: 17
hey james L... if i turn up the gain and bass boost on the amp... its not going to give too much power to the subs and end up blowing them? are they?... im always confused about that s**t... like i want to put it full power... but worried... it shouldnt matter right?... because both of the subs are 300 watts each... and the amp is giving them 300 watts so i guess it doesnt matter if u turn up the gain all the way?
