X-x-x 10" amplifier match?
Username: Artofaccuracy
Post Number: 40
What kind of amp and box should I match with a 10" x-x-x.
I have a 1986 mr2 (2 seater) and there theres not too much room behind the seat. What is the most efficient box to put it in that will give it it the most bang for the .. size. I'd like like the sub to have full power for every single hit .. fully exhausting all of its power.
werd
a hifonics bx1500 would probably work. Unless you want a higher quality amp but its pretty efficent for the cost. some people have good things about a triple x and ed.nine1.
Username: Taylor17
Kopperl, Texas
Post Number: 1784
Yup, the 1500D is a good amp. Do you want sq, or spl. I would go ported though.
Post Number: 42
Id rather have a mixture of the two. I'd say more SQ if I had to decide. Like I said ... Its a two-seater. Theres a triangle shaped space behind my seat (made by the firewall, back of the seat, and the ground. Theres a decent amount of vertical height, but not much horizontal. Id say a foot and half maybe.
