Are those subs still there at ascendant audio???/
DANNIIIEEEE
i need to get one 15" atlas do you think they still have them?? i can't find the link or the number of the place
btw do you guys think 1 15" atlas is going to be loud enough to be heard from awhile away(or would 2 12" kicker comp cvr's be better?)
Username: Dpaw20
FL USA
Post Number: 185
www.ascendantaudio.com
call to order
DANNIIIEEEE
what do you think about the 1 15" atlas vs. those 2 kicker comp cvr's??
Username: Cenus
Hicksville, Ohio Usa
Post Number: 87
i called today and he said he some left i ordered 2 15's, as for the comparision i would think 1 15 with more x-max and a better motor would get louder than those kickers
Username: James1115
Wilton, Ct
Post Number: 2775
chad said he should have ebough to last about 1 week thats it so dont delay on this guys!
Username: Invain
Michigan United States
Post Number: 2195
No, stop. Nobody buy anymore d@mn 15" Avalanche's. Get 12's or 18's.
Username: Rob315
Cuse, NY U.S.
Post Number: 470
2 15" cvrs will definitely be louder.
DANNIIIEEEE
so which one is it guys??? lol because the kickers are alot cheaper
Username: James1115
Wilton, Ct
Post Number: 2809
Hey rob he was comparing the comp 12's and in this case I would go with the Atlas:-)
