What would be a good amp for.........
Username: Jthree
Bay area, Ca Usa
Post Number: 63
2 12 inch eclipse titaniums?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 311
personally id run a zapco 750.2 to each. ... although i dont know the ohm configuration on the subs and thats very useful information
Username: Jthree
Bay area, Ca Usa
Post Number: 65
dvc 4 ohm.
Post Number: 312
hmm, well that wouldnt work... your going to need either 2 2 ohm stable amps or 1 amp that can very upon what u choose... if u wire the VC in parallel and the subs series you get a 4 ohm load, if you wire the VC in paralell and the subs in paralell you get a 1 ohm load. ... im really tired... i think thats right
how much money do you have?
Username: James1115
Wilton, Ct
Post Number: 2785
try a JBL bp 1200.1 or a Kicker 1200.1 they are both 1ohm mono stable. I would do the Kicker it would really make those subs move, I believe they bench test at around 1500 watts at 14volts so it would be perfect.
Username: Jthree
Bay area, Ca Usa
Post Number: 67
what about the mtx 1501d. would that be better considering i hear the eclipse subs are underrated
